Can I adjust travel of hydraulic cylinders on FEL?
frysl
L3301 LA525 FEL & FDR1672 6' Finish Mower
Jun 13, 2016
Sumner County, TN
Id like to adjust the travel on the hydraulic cylinders the curl/dumps the loader bucket. I would like to take just a little bit of the curl out. is that possible?
8,699
Technically you can do it if it's on the stroke where the rod is internal, you would have to take the cylinder apart and add an internal stop, for external stops, D2CAt put them up.
My biggest question is why?
5,646
you 'could' cut /hack off the mounting trunnions, make new ones, weld them onto the bucket. usually by the 3 rd or 4th attempt the sky goes gray ,being filled up with #&^%(four) letter words......
there's 3 or 4 other ways ,all involve money, time and effort......
hopefully the 'spacers' will do it though....
frysl
Jun 13, 2016
Sumner County, TN
I’ve noticed that since putting the quick hitch adapter on, the curl/dump cylinders will now retract about an inch more than previously.
8,699
Ok, But why is that an issue?
3,871
2,517
Adjust the travel using the joystick thingy on your tractor
what are you really wanting? change limit stops?
5,646
hmm I though 'quick hitch' was on the back( 3ph) or is that the new 4 point subframe for snowblowers and plows or does it mean the SSQA system? It's getting easier to get cornfused as I approach 70......
8,699
SSQA adapter for the loader. ;)
5,152
Wait till you turn 80, then you will really be confused! You won't know which way is up or down! Oh, by the way, what is "confused"?
