Under Seat PTO Switch
rockster
LE3560HST; LA555 Loader; 6’ Finish Mower; Grapple & Forks
Sep 15, 2021
31
12
Inverness; Florida
I just installed a PTO switch on my L3560LE that mounts on side of seat to keep tractor running when I get out of seat with PTO engaged. How come the tractor still shuts down when I get out of seat. The connector was there already just had to plug it in and screw it down. ED71D35E-E114-4F37-8F62-BB3010FEB6C8.jpeg
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
I don't know how the new 3560LE is wired up, so you should get a shop manual to identify the part you connected to. Wiring diagrams and parts lists can be found online at Kubota website. However the 3560 has a seat switch INSIDE the seat, so you may not have connected to the right part.
Fordtech86
L3200
Aug 7, 2018
4,966
5,919
Pineville,LA
I don’t know the difference in the 3560 and 3560LE. But the 3560 manual clearly shows two sensors. One in the seat and the tilt switch is external.
Fordtech86
L3200
Aug 7, 2018
4,966
5,919
Pineville,LA
I just installed a PTO switch on my L3560LE that mounts on side of seat to keep tractor running when I get out of seat with PTO engaged. How come the tractor still shuts down when I get out of seat. The connector was there already just had to plug it in and screw it down. View attachment 66573
hard to tell from the pic, but is that connector fully seated on the new switch? In the picture it looks like it may not be?
rockster
Sep 15, 2021
31
12
Inverness; Florida
Well there is one two wire connector going to switch in seat. The second two wire connector in picture is the one I connected the new switch to. It is fully seated as I checked. The difference between the L and LE on the LE there’s no cruise control switch…No PTO Switch (The one I just installed) and there is no seat tilt switch. So I know it is wired correctly as it is plug and play. Why it’s not working is beyond me.
Fordtech86
L3200
Aug 7, 2018
4,966
5,919
Pineville,LA
Do you have the seat flipped up before engaging the PTO or are you engaging it while sitting in the seat then getting up and flipping the seat?
rockster
Sep 15, 2021
31
12
Inverness; Florida
. If I’m seating in the seat with PTO engaged and I want to get up with PTO engaged the tractor shuts down. The switch I installed is supposed to keep tractor running while out of seat.
Fordtech86
L3200
Aug 7, 2018
4,966
5,919
Pineville,LA
The way I read it you need to have the seat in the flipped position before engaging the pto
rockster
Sep 15, 2021
31
12
Inverness; Florida
Well I guess that defeats the purpose I installed the switch for. Im going to try that later today. Thanks For You Response. 👍
rockster
Sep 15, 2021
31
12
Inverness; Florida
I guess that’s only for running a generator; ect when not in tractor. Guess I’m going to have to unplug the wire going to switch inside seat and put a jumper wire on it.
3,399
I do not have seat switches on either of my tractors. So I personally do not see the need for them, but do realize they have to offer some form of extra protection.
What I would do is get out my roll of electrical tape, and just tape the switch in the position that it normally is when the seat depresses it. Problem solved, at the expense of losing whatever protection the seat switch offers, as compared to not having one to begin with...
Edit: the switch is inside the seat? Might be more difficult to tape it then...LOL.
B737
LX3310
Jun 9, 2019
2,022
2,205
would it be easier to just trick the operator presence switch to thinking someone is on the machine? (being mindful of losing a safety system)
Im not sure if the seat is similar to the ones on the LX or B series, but if you remove the bottom of the seat cover (~6 screws) the seat switch is exposed and you could just jumper it with a piece of wire with two blade connectors
seen here bottom middle.
rockster
Sep 15, 2021
31
12
Inverness; Florida
Great idea. But there is no way to get to switch inside the seat. Guess they don’t want you to disengage it for safety reasons.
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
I have a regrettably dim memory of dealer removing a panel on the back of seat to adjust mine with a piece of cardboard since I wasn't heavy enough to keep it running when go pedal was depressed. So it is possible.
5,164
You could wire in a toggle switch into the wire coming out of the seat, that will bridge the two wires when the switch is flipped to the on position. That way, you can turn it on or off whenever you want to. No need to dig into the seat itself.
rockster
Sep 15, 2021
31
12
Inverness; Florida
Great idea. Never thought of putting a toggle switch in. This way when I’m mowing and think something is wrong I can just flip the switch and can get out of tractor and it will keep running. Thank You 👍
5,164
It will also protect you in the event that you are tossed off the tractor or some other type of accident, where you want the tractor to stop immediately. Nothing worse than being run over by your own tractor.
rockster
Sep 15, 2021
31
12
Inverness; Florida
Yeah I guess your right. Safety First. I do have a cab on mine. But you never know what will happen. Thanks 👍
rockster
Sep 15, 2021
31
12
Inverness; Florida
I seen what you wrote in the email I received. I just want to put a switch there so when I think something is wrong while mowing I can get out and tractor doesn’t shut down and see what’s going on. But leave switch engaged all the time. Don’t want it bypassed all the time.
