hotnoob, you dug that with your fel? I am impressed, the machine and the operator. I would have never began such a job. Then I have small excavator.
Thanks for posting those guidelines. I don't have a backhoe and have wondered if push comes to shove could I safely bury a sheep or a horse with a light materials bucket dug hole. Part of the back pasture is sandy, more of that glacial stuff. I think a sheep maybe, not a horse.Looks like sandy, glacial till.
Now, please don't take the following unsolicited advice the wrong way, but:
What you have there is an 8' deep death trap.
My day job includes attempting to rescue people from the bottom of such trenches after the sides collapse. Usually on "small", "quick" jobs like service connections and trenches for drains and wells. People think that these jobs are not dangerous enough to be worth safeguards.
But what often happens is the top corner of the trench wall suddenly collapses and the person working in the trench is partially buried. If they are buried up to the chest, the soil pressure prevents them from inhaling and they die quickly. If the depth of bury is lower, it still can rupture things inside, they bleed out internally and they die slowly.
Your spoil pile is not along the top edge, which is good. But you still need the sides tapered back at least 45° all the way to the bottom, or use shoring. If the soil is wet or loose, then more taper is needed. Unless the walls are solid rock, never enter a trench deeper than 1.2 metres (4 feet) if it is not properly sloped, shored, or protected by a trench box.
Again, I don't mean to insult you, your efforts, or your intelligence, but I am very well trained and experienced (over 30 years as a firefighter and a company officer, currently serving with a heavy rescue squad). Please take this to heart. I've seen too many preventable deaths.
Got a few in the back pasture and mine is sandy which is kind of typical here. Always dig them at least 2 rimes bigger than needed and never enter them myself, always in the tractor. MDNR now prohibits that, must be composted and I use my buddy's compost pit for steers, would most likely use it for an equine as well but we use Partridge Services in Sand Lake now.Thanks for posting those guidelines. I don't have a backhoe and have wondered if push comes to shove could I safely bury a sheep or a horse with a light materials bucket dug hole. Part of the back pasture is sandy, more of that glacial stuff. I think a sheep maybe, not a horse.
yeah; i originally planned on only going 4ft; digging the last two by hand, and relying on insulation for the rest of the depth, but, around 3ft hit some hard sand / clay / dolomite mixture. i used a pick to get through this by hand where i had to. with the FEL i scraped away the top with very long runs, digging in by ~ 1/2" per scoop.Looks like sandy, glacial till.
took about 20-25 hours.I get the safety concerns, but that is still an impressive ditch. Does that represent all 77 hours on the tractor, or just some? Which type of tooth bar do you have on the FEL bucket?
I was wondering if I had a PTO driven tiller if I'd even need a tooth bar? Till first, then scoop up 2-3 inches per pass (or maybe 5 of that sandy stuff)?took about 20-25 hours.
prior to that, tilled a few acres of field, and a few small pits.
no toothbar, but i've been looking at getting one.
for the sand, cuts like butter ( traction is a huge issue ) get stuck A LOT if i don't back pull, in the sandy parts, have to back pull every scoop. oh, and 100% make sure you got SUDT2 / Premium UDT; without it my tractor was stalling every time it got a tiny bit stuck in sand. even just tilling the field, stalled a few times, when the soil got softer. still a bit peed that they put the wrong hydraulic fluid in my tractor when i got it new >.<I was wondering if I had a PTO driven tiller if I'd even need a tooth bar? Till first, then scoop up 2-3 inches per pass (or maybe 5 of that sandy stuff)?
You were not kidding!!! Are you expecting an attack from the east?der. i did the rest by hand;
Maybe he could offer you a hunting trip or vacation for the help package. Would be a tad to haul a tractor though.Hotnoob, I am impressed with your work ethic! If you were a neighbor I'd be over to help.
