Fish Lifes B6100 Restoration
6,634
FishLife, folks think Kubota paint at the dealer is expensive....they haven't priced at your store!!
I'm guessing it wouldn't take much more than a quart of orange and one of blue to do your B6100. You put the hardener in there and that makes the paint go a bit further.
FishLife
177
Destin, Fl
Looks like you got one heck of a project going. Hopefully getting my L260P back to life isn't going to be nearly this extensive. Good Luck!
I didnt originally plan on doing this much to it. Somewhere along the line I realized it was going to be more than I thought and decided to completely restore it like the day in came off the assembly line. This tractor will never see farm life again as long as I have it. All it is going to be used for is a little mule to maneuver my boat and equipment trailer in my drive. Good luck on you adventure and I will be following along.
FishLife
177
Destin, Fl
This thread is seriously lacking pictures
Sorry to disappoint. There is just not much to show at the moment. Just a lot of dismantled parts. The dealer called me this morning and a large order of parts had come in. So from this point forward I will be able to start posting the rebuild part of this project.
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
447
NZ
I didnt originally plan on doing this much to it. ... This tractor will never see farm life again as long as I have it. All it is going to be used for is a little mule to maneuver my boat and equipment trailer in my drive.
FishLife is satisfactorily transitioning from hooked on fishing to hooked on Kubota tractors as per textbook. Keep up the good work team :D
6,882
Fish - great photos - like your shop.
It probably sounds foolish, but I like the paper plates with the small parts. Much easier to see than baggies, and I never write well enough to read my bag labels.....
FishLife
177
Destin, Fl
Thanks.I got the idea from a YouTube video of a guy restoring a car. Before I saw the video I had several of those oil drip pan trays with little piles of parts trying to keep them sorted. You do have to be careful not drop the plate or knock it off the bench. Nothing wrong with bags but I like the plates. Maybe cause I havent dropped one yet.
FishLife
177
Destin, Fl
There was delay in getting all my parts do to some confusion at the parts counter. I have been at a stand still waiting on the correct parts. Finally got them late last week. I changed all the oil seals and gasket in the rear and stripped the old paint that was pealing on the aluminum portions. I gave everything a good steam clean and this section is ready for paint. I have some time off so I’m going to work on getting the engine all back together now.
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
441
42
Atascadero
On your aluminum parts, you might want to look for a aluminum primer that etches into the metal and helps the finish paint stick.
torch
Jun 10, 2016
2,745
965
Muskoka, Ont.
+1. Zinc chromate primer is best for aluminium.
FishLife
177
Destin, Fl
Forgot to mention in my previous post that I decided to go with the PPG paint and epoxy primer and SEM rattle can etch primer for the bare metal portions. I took a piece that I had painted with the Kubota rattle can to have them match. They had a color code already for the blue and both oranges. The blue is in the PPG Delfleet product and the orange is in the PPG Shop line product. I will attach the paint labels for others if they want to go with PPG paint. The label is for the old orange.
FishLife
177
Destin, Fl
I havent been able to paint the rest of the parts yet do to the cold front we got. In the meen time I started replating the nuts and bolts and othe hardware that doesn’t get paint. Also working on things around the house for the wife. But still moving forward. I plan to get the engine on the bench to mount the flywheel and starter to bench test it before I mount it back to check that it is running good. Hoping to get that done by next weekend.
DoubleDurgz
B6100D
Dec 16, 2018
44
North East, MD
How are you tracking all your Rods, linkages and springs? I’m starting to get concerned when I have to put it back together. I did get this manual but the pics aren’t that great.
FishLife
177
Destin, Fl
How are you tracking all your Rods, linkages and springs? I***8217;m starting to get concerned when I have to put it back together. I did get this manual but the pics aren***8217;t that great.
I have tags attached to some things. All the small parts I separated on white paper plates with a discription of what it is and where it goes written in the bottom of the plate with a sharpie and placed on a wire shelf rack. As I took it apart I put things in groups. Like in the motor anything fuel related is on one plate, valve related on another, bolts for the right floorboard on another and so on. All the larger parts I have hanging another rack.
6,634
FishLife, nice work. Your attention to detail leads me to think in your previous life you must have been an aircraft mechanic or a surgeon!
