Putting weight on the front of Bs
mike paulson
232
27
ulster, NY
Hey fellas, I need some ideas. I was out plowing snow with my b2620 and it was about 14 inch's deep. The little machine did great but occasionally the front end got pushed over a bit here and there. I have chains on the rear and weight in my dirt scoop and the rear stayed put.
But I'm looking for ideas to get more front wheel traction? Oh I must add that I have the Kubota 6ft snow blade and sub frame assembly setup.
BAP
Dec 31, 2012
2,996
1,097
I put a set of tire chains on the front of my B2920 along with a rear set. Makes a tremendous difference in the steering. I had a pair that came off my old lawn mower tractor that fit and were light weight.
TobyGaff
B3300 with FEL
Feb 11, 2014
Northern Indiana
Another option is to use a product like RimGuard. It adds a fairly significant amount of weight to the tractor, although not all to the front of the tractor since those tires are smaller, but the extra weight does help the traction.
http://www.rimguard.biz
9,130
Read your manual, Most if not all tractors DO NOT recommend filling the front tire with liquid! ;)
gpreuss
Oct 9, 2011
1,166
Spokane, WA
Keep your eyes on local garage sales - you can often find weights for a song. I like the looks of the brackets for them.
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
I would be concerned the the extra weight from the front wheel weights would over stress the front drive train & steering of the 4x4 system. Does anyone else feel the same way?
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
I think the biggest problem is trying to push 14 inches of deep snow with a 6 foot blade on a subcompact tractor. I run a B6100 with a 4ft blade, sometimes its all it can do to push snow, it works better pushing snow backwards then forwards.
mike paulson
232
27
ulster, NY
Are you kidding, it pushes better than some full sized P/U's I've seen. And pushing snow up a 1/2 mile long private road backwards isn't an option.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
I do not believe the wheel weights would particularly hurt the front end, other than making it pull harder. You get into trouble when you try to space out the wheels. Simply adding a wheel weights is probably easier on the front end than suitcase weights .
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Mine walks sideways to much if I drive forward with the blade at an angle trying to move snow from oneside to the other. If I spin the blade around and push backwards I do alot better.
I don't understand how such a small tractor roughly the same size as mine is pushing a 6ft blade, but if it works it works.
mike paulson
232
27
ulster, NY
I was watching a neighbor with a similar sized New Holland today and he had chains on the front wheel and no apparent weight on the front and he was pushing todays snow with much better results. I also noticed today plowing 14plus inchs that alittle less blade angle and alittle more speed helped keep the front wheels in line.
Still getting used to this little tank, only had it for a month and this only the second or 3rd snow fall I've plowed with it.
Gotta add this tractor runs cirlcles around my 4500 lb Massey 50 when it comes to pushing snow and just about everything else.
I will be heading to Tractor Supply tomorrow for a set of front chains and am certain now I will be good to go.....
kubotasam
Apr 26, 2010
1,211
134
Alfred Maine
I run chains on front and back of both of the B7100 tractors that I use in the winter. Have used then this way for years. I also have 50 lb wheel weights on each front wheel of the tractor with the back hoe mounted. Not so much for snow moving traction but to keep the front on the ground to counter balance the weight of the backhoe when going up steep hills.
bmwmike
B7100, 1640A loader, tiller, box blade, grader blade, carry all. John deere 455,
Jan 13, 2013
79
clarksville, Tn.
These may be able to be put on front wheels and use free weights.
http://lugghandles.com/
I made my own for the rear and would do the same for the front if I needed them, very easy to make. I got the weights at the scrap yard for 22 cents a pound. I did 100 lbs per rear wheel.
mike
mbnorton
canada
Just a thought
Since you have chains on rear and have a front blade...... why not remove weight off the rear. If you add weight on front you will remove weight off of the rears?????
Dan_R_42
Dec 1, 2010
447
Taunton, MA
Just a thought
I'm trying to keep an open mind here, but not sure I follow the logic here. Please expand on what you are thinking, on how and why that would work.
mbnorton
canada
you are using a front blade. If you are that is weight on your front tires. The weight on the dirt scoop on your three point hitch removes weight from front tires and put more on your rear tires. the rear wheels acts as a pivot. Remove weight from rear dirt scoop should add weight to your front tires by pivoting on your rear tires. Like a see saw. I am not saying it will work just try.
mike paulson
232
27
ulster, NY
Still need the weight on the rear for pushing piles and drifts....
