White smoke at high RPM
Orange2009
Kubota BX25, BH, FEL, 60" belly mower, 48" tiller, Middle buster, Stripe kit etc
Mar 25, 2013
39
Oxford, Ohio
I have a video on my phone but not in a good wifi area at the moment to post it.
Orange2009
Mar 25, 2013
39
Oxford, Ohio
Ok well.. Pulled the valve cover and everything "looks" ok now I know you really need to pull the pieces to check for straightness ect. Since I'm not 100% sure how to find TDC on each cyl I turned it over and found "close to TDC" and each rocker had play, didn't seem like too much but yes this is a quick inspect and I didn't have my feeler gauges with me. Soo I fired it up, good news is there isn't any smoke coming through the head so I would assume we can cross valve seats an guides off the list. Bad news is I'm guessing this means a ring and or scored cylinder wall. As soon as I can find torque specs... And time ill pull the head I guess. Also there was a small amount of smoke from the dipstick tube after ability down. So I am guessing rings.
Local parts shop had plenty of compression gauges... None for diesel though.
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
441
42
Atascadero
Sounds like a sticking injector. I didn't seem to see anyone suggesting some good fuel injector cleaner and maybe a good dose of Marvel mystery oil or some ashless 2 stroke oil with the injector cleaner FIRST before going with pulling the injectors.
hodge
Nov 19, 2010
2,938
500
Love, VA
Harbor Freight has a couple different diesel compression tester sets.
Orange2009
Mar 25, 2013
39
Oxford, Ohio
Ok makes sense because it only does it at high rpm BUT would a hydrolocked situation like I caused do this? And would it burn oil... Or what it seems that it's doing right now.
Wild and Free
B2150 HSD w/Case L340 fel 68" quicktach bkt, 60" jinma snowblower, box scraper
Oct 25, 2012
390
North Dakota
I actually suggested the ash less 2 stroke oil a few pages back already.
Don't bother wasting time on injector cleaners as a vast majority are alcohol based and with todays low lubricity fuel can cause more issues.
I would just suggest takeing the injectors to a fuel shop for a check up. Blue at high rpms is a sign of raw fuel yet.
Orange2009
Mar 25, 2013
39
Oxford, Ohio
Yea wild I remember the post... I need to try that just time hasn't been on my side
kuboman
721
It sounds like injector/delivery valve problem. As suggested earlier I would use a good injector cleaner/ conditioner. I said good. Some do contain alcohol but most do not. Most high speed misses and smoke are injection related. A conditioner is a cheap way to start. Don't expect miracles but it might help.
Orange2009
Mar 25, 2013
39
Oxford, Ohio
Not sure if you read all the posts but this was after a hydrolocked situation. Would that cause this? Also I don't want to help it I want to fix it. I'm hoping it is a head gasket between 2 cylinders if the 2 stroke oil doesn't work. Used to do it every full up on my trucks but got lazy and tired of measuring out.
Orange2009
Mar 25, 2013
39
Oxford, Ohio
Here is a video of a cold start. And what it's doing, I had to load over 3G so not sure how the quality will be.
http://m.youtube.com/watch?v=1onSum8btiQ
kuboman
721
I doubt you had hydraulic lock. That would cause a bent rod and weak compression in at least one cylinder. I have seen your situation before and every time it was worn injectors and or delivery valves. You tractor like ate some water through the diesel and scored up your injection system. I would still try a good injector clean and conditioner and it might spruce it up some.
woops, thought I was responding to the OP. Sorry. I direct my comments to the OP.
Orange2009
Mar 25, 2013
39
Oxford, Ohio
It was hydrolocked I got coolant into the intake. This was not a gradual thing it was immediate after maintenance. But I screwed up and some coolant spilled into the intake from the top radiator hose. I'm not wanting to sound like repeating myself but this wasn't a "over time" thing. This was like:
Perfect tractor but time for maintenance.....
While I'm at it lets replace that cracked shroud...
And have a beer...
Boom dumb mistake..
Try to start it... Hmm battery must be dead..
Another beer...
Try again. Cranks over, rough, starts and mediate smoke. It was hydrolocked... Or well I should say enough coolant in at least one cylinder to cause an issue.
Orange2009
Mar 25, 2013
39
Oxford, Ohio
Well put 10oz of 2 stroke and let it run for 45 or so minutes, including driving around, no heavy work/digging ect. The smoke seems to be a lot better BUT not gone. There is a prominent miss fire sound at higher rpm or when I take off or lift bucket. Called dealer and he estimated 1,000 in labor. That's IF it's a rod. Plus parts. I explained everything to him that I did to screw up plus tried to diagnose and he said that he will almost bet there is a bent rod. He said the starter has every bit of enough power to bend one.. He also said that it may need a little bit of honing to the cylinders, and that's why the 2 stroke oil is helping (coating the walls) sounds like a trip to the dealer it is.. Sad news but I have over $22,000 tied up in this machine and with only 394 hours I want to make sure that it's fixed properly.
Apogee
Jan 22, 2012
522
Tacoma, WA
Orange,
Huge bummer!
Why don't you tackle it yourself? These engines are fairly simple. At the very least, you can pull it down and find the problem yourself. You will learn a lot in the process and will feel good about the finished product. Yes, it might cost a bit in tools if you don't have what you need, but it will still save you a bunch in labor cost.
They should ABSOLUTELY hone/re-ring it while it's apart. I'd also have the head checked for cracks and the valves ground while I was at it.
You can do it!
Just my $.02,
Steve
Orange2009
Mar 25, 2013
39
Oxford, Ohio
Orange,
Huge bummer!
You can do it!
Just my $.02,
Steve
Yea trust me I want to and have been around engines and inside a handful, thing is time, tools and space to work on it is the issue... I'm praying its a head gasket between 2 cylinders. If I did it myself I'm thinking with my work schedule it would take me over a month... I also have a few sidewalk tear outs, and a couple retaining walls to do. So I guess it's better I just have it done ASAP
Apogee
Jan 22, 2012
522
Tacoma, WA
Yeah, it makes sense...
Fingers crossed on the head gasket!!!!
Please keep us posted.
Steve
Orange2009
Mar 25, 2013
39
Oxford, Ohio
Well took the tractor to the dealer yesterday to have them give their opinion. He said that he bets its a bent rod... we will see when they run some tests. tomorrow there gonna do a compression test, and then go from there. I told him i was hoping that it was the head gasket but he said that while it is possible, i would have better luck with the lottery.
hodge
Nov 19, 2010
2,938
500
Love, VA
That doesn't sound like a good way to start the week. Thank you for the updates- besides curiosity, it is a good learning curve for everybody. Keep liquid out of the cylinders, unless it's diesel.
Orange2009
Mar 25, 2013
39
Oxford, Ohio
Well the dealer called and said he ran several tests geared towards a bent rod.... from the sound of his voicemail everything passed, they tested the fuel and found it to be "Bad" im not sure what all they tested and by the time i got the message they were all closed, so I'll call tomorrow to get the details. Im not buying that it was the fuel AT ALL but hey im down with that if its the truth, and after I approved them 1,200 in labor i dont see why they would have any reason to be dishonest. Im still totally lost at how it would run like a top to locking up to running like crap after a basic service and coolant flush.
is it possible that the piston forced coolant the "wrong way" into the fuel system?
davemskinner
Sold ZD28F, Bought04 Grnd L4330 /frnt mnt snwblwer L2185, hted/AC cab, 2nd ZD28F
Mar 12, 2011
96
Pulaski, NY
Not so much force coolant into the injector the wrong way but, maybe bent the pintle causing the injector to perform poorly. The whole thing smacks of injector trouble. Looking forward to hearing the final result. Good luck!
