Trailering your tractor
DanR
26
Moncton, NB, Canada
well it all went great aside from rain! But what are you to do with one day off during the week. The trailer was fine and not over loaded at all. Even with the rain i managed to test it out some and put a solid hour on it. I love this little thing!
Sent from my SM-N920P using Tapatalk
Congrats! I can't wait to get mine next week!
Helpful tip.... You should always cross your straps over. Right strap on the tractor ties over to the left of your trailer, etc. The higher the mounting points on the tractor the more important that becomes. You'd be surprised how much even a little side-to-side play can shift the weight of a load.
TRA
B2601, LA434, BH70, LP BB1260
Dec 17, 2017
88
Rock Hill
Rent a tandem axle trailer or flatbed car hauler if you need to move it infrequently.
A good trailer will run you $3K. A rental might run $50 per day.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
I never liked the single axle I had because it was all but imposable to get the correct tongue weight.
People do crazy stuff all the time and get by with it to a point I guess. One of the last trips to the stockyard I made I had a Dodge caravan pass me going about 80 with a BX25D on a single axle trailer.
shootem604
Apr 23, 2018
874
British Columbia
Here in BC most single axle trailers with a utility license plate are registered for a maximum GVW of 1440kg and are built with a single 3500lb rated axle. That's not enough for most small tractors - highly recommend a double axle trailer. Also, as others pointed out it is harder to get the weight placement figured out for safe towing.
torch
Jun 10, 2016
2,879
1,125
Muskoka, Ont.
The OP's tractor is listed as 1443lbs. Add a thousand for the trailer itself and, say, 600 for the FEL and another 300 for a counterweight and he should still be within the axle's rating. Don't forget, 10% of the total weight is on the tow vehicle, not the trailer axle if it's balanced correctly.
If he's using it commercially and trailering it regularly, then perhaps a bigger trailer would be in order. But if he's just running it back and forth between dealer and home two or three times a year for service, he should be just fine.
bearskinner
Sep 1, 2014
926
242
N. Idaho
“OVERKILL IS UNDER RATED” I would worry so much about using a single axle trailer to tow my tractor. Peace of mind, using a dual axle trailer with brakes and load stabilizer, are worth far more than money saved on an inexpensive trailer.
I also would feel guilty for life if I caused an accident towing with a barely adequate trailer.
pinstripefan90
BX25D, FEL&BH, Piranha tooth bar, Bucket hooks, Pallet forks, Back blade
Sep 8, 2017
49
New York
I have towed my BX25D on both tandem axle trailers and single, it is much nicer on the tandem but similar to you when I brought home my tractor from the dealer I used my single axle landscape trailer and it was a 1hr + long ride, I have moved it again with the single very short distances but anything long I get/borrow the proper trailer, also when loading and un loading make sure to place jack stands on the rear of the trailer, especially the single axle one.
- Jake
Ping
BX2370-1
Dec 25, 2018
362
378
Troy, Ohio
18' tandem with brakes for my BX. As stated earlier 'overkill is under rated'. I have plenty of deck to work with and it tows well behind my 1/2ton Silverado
Regards
Ezlife45
B2650
Jun 5, 2014
172
Louisiana
I tried running my B2650 with a blade and FEL on a 5 x 10 and I'll never attempt that again. My other option is a steel decked dual axle trailer with dual axle brakes. Sure it takes more to get it out and up and loaded, but I like the piece of mind.
troverman
Jun 9, 2015
1,178
266
NH
Does this count as overkill? Lol.
My B2920 with a 4-foot flail mower on a 20' trailer rated at 16.5k GVWR behind my 2017 F-350 dually rated to pull 31k...
torch
Jun 10, 2016
2,879
1,125
Muskoka, Ont.
From this angle, I only see one ratchet strap over the floor boards to secure the tractor to the trailer, so I'm gonna say "No". :)
troverman
Jun 9, 2015
1,178
266
NH
Lol. There was a chain on each end too but those were taken off and I snapped a pic before yanking that last strap.
I haul larger tractors on that trailer, too...my MX4800 frequents that trailer along with a 6-foot flail mower.
flyidaho
L 3301 HST
Feb 28, 2017
428
255
IDAHO
Several times over the last 10 years or so, living near a junction of two major interstates like I do, I have seen a heavy equipment low boy trailer, obviously deadheading back from his last heavy haul, with a Tonka Toy type loader, maybe 24" long at best, lashed down to the bed! I'm sure he makes the Port of Entry people's days when he rolls over the scales, plus little kids as he drives down the road. He probably isn't the only trucker who has thought of the idea, but it sure cracked me up.
200mph
Mar 3, 2017
1,229
66
PA
I'm just under 6K#'s. My F150 Ecoboost doesn't even know it's back there. :)
If you're F150 doesn't know the trailer is back there, something is drastically wrong with the vehicle electronics/software! :D:D:D
wwiifan
2017 BX23S
Jul 13, 2017
21
Salina, Kansas
You'll get a LOT of naysayers here, but I haul my BX on a very similar trailer to yours all of the time. If you are going real long distances at interstate speeds on a regular basis, I would probably opt for a tandem too, but for semi occasional use, I wouldn't think twice about the single. Also, your tractor shouldn't weigh anywhere close to 3400 LBS. I couldn't find a spec for the 80 series loaders, but the tractor and 60" mower is only about 1700 LBS.
Loving the Buick Wheels on your trailer...!!! My dad was a big Buick fan also. We have Buick wheels on everything on the place...
nbryan
Jan 3, 2019
1,420
939
Hadashville, Manitoba, Canada
I got a 7000gvw PJ trailer, dual braked axle with beaver tail. My B2650 with BH77 backhoe and L534A FEL weighs about 3500 lbs altogether, and the trailer weighs about 1800 lbs, so towing weight is about 5300 lbs. I back on to the trailer and put the loader down flat to the deck with lead edge just touching the rearmost deck angle rail (where the ramps hook). Balances the load perfect.
My 2006 4wd Tacoma X-cab hauls it no problem.
I find the beaver tail to be quite handy when I trailer the tractor with my front mount snow blower attached, as the blower only raises about a foot fully raised and would drag on the trailer deck while loading without the beaver-tail.
~3500 CA funds for the trailer, new, 2018.
Neil
