Tractor - 1 Flesh - 0
olthumpa
L275
May 25, 2011
1,505
Maine
OOOOOOUCH :eek:
With 4 days in the high 40's to low 50's and having 16 people over for Christmas, my driveway has turned to mud heaven. With the temperature supposedly going below freezing and staying there for 4 to 5 days I thought that I would take the opportunity to back drag it and level out the atrocious ruts that have mysteriously developed. TO assist in leveling things out I put my counter weight in the bucket and chained it there. This proved to be very effective. The problem occurred when I was putting the weight back where it belonged. I had put 1 chain through the pin that the top link attaches to and attached it to a grab hook on the bucket. Took a second chain hooked it to one side of the bucket down under the draw bar that is bolted to the weight and secured the other end of the chain through a loop in the end of the buck back onto it self.
The 3pt hitch does not go down far enough for the weight to rest on the ground so I use 2 large solid cement retaining wall blocks to set it on. I undid the lower chain and carefully slid the weight out of the bucket using the hydro's then lifted it with the top chain and set it on the blocks. I left a couple of inches of slack on the top chain both for safety in case the weight was not properly balanced ans so I could undo the top link pin. Got off the tractor - wiggled the weight a little to see if it was sitting securely. Undid the chain from the bucket and started to undo the top link pin to remove the chain. That is when the weight decided that it was not properly sitting on the blocks. Jumped back but not far enough or fast enough. The top of the weight scraped down my upper thigh across my knee and down the outer shin. Thanks to my wife putting an extra layer of heavy canvas on that exact part of the legs of my work pants, the weight did not tear through the pants but scraped down the outside. I did loose some skin and am sure that I will be displaying some nice bruises for a while.:eek:
Morel of the story: Shit happens no matter how careful you are. Don't tempt fate by disregarding safety rules and procedures.
11,048
Been the same way around here, MUD, MUD, MUD! :eek:
I made about the same kind of boo, boo, I was walking around the blade, pulled the pull the pin, spun the blade and slipped on the mud a little and caught the inside of my leg on the blade, OUCH!!!!
So my moral is: ;)
I feel your pain brother! :(
All donations of pain medication can be divided between us, I prefer mine in the Wild Turkey version! :D
3,058
So my moral is: ;)
Just got off the BX.....no real boo-boos yet.........but I too am looking for a ...drink !!! @#$%@#%@#$ rain comes tomorrow!!!! :D
5,565
Man I thought I was the only one dealing with a mud chocked driveway,, And I just finished a small glass of some homemade peach pie shine,,, No wonder granny was smiling all the time after she canned peaches,,, hmmm maybe they weren't canned but pickled,,,lol
olthumpa
L275
May 25, 2011
1,505
Maine
Yup, called it a day. Came inside and checked out the damage. Took a shower - hot water and raw skin do not mix very well.:eek: Poured a little something sat down and the paine went away.;):D:cool:
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
Aah the perils of cussing 3 point equipment. Makes me yearn for the days of allis chalmers snap coupler. hope all heals well...
hodge
Nov 19, 2010
2,960
531
Love, VA
Sorry that happened! You are going to be sore tomorrow!
olthumpa
L275
May 25, 2011
1,505
Maine
"do not put off until tomorrow what you can do today"
I am already sore.:eek::)
You play sooner or later you pay. It could have been MUCH worst. If I did not move when I did, it would have crushed my leg and pinned me under it. My wife has been sick and in bed for 4 days and did not know how long I was going to be outside. It would have been hours before anyone might have come looking for me.
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
Double AAArg....
And a thought for anyone outside for hours with no one around. I have taken to leaving a cheap "burn phone" always in my barn coat pocket in case I fall out of the hay loft or something. If these phones are left all tne way off the battery holds its charge for months.
I've been told that any cell phone even if no longer on a contract can at least call 911. So old cell phones can be charged and stashed where they might come in handy in case of disaster instead of recycling them
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
Sorry to hear of the ouchy. Mine has giving me a couple of nips just to remind me that steel and skin are frequently incompatible. Get better fast.
My friends always accuse me of over engineering things and playing it too 'safe' but I've avoided a lot of accidents doing so and my stuff still stands even after their stuff falls over so I'm staying the course.
I hear your advice and try to live by it!
olthumpa
L275
May 25, 2011
1,505
Maine
I try to always do things the same way, if it has worked before with out any problems don't change. If someone suggest a different way of doing something, or I think of a better way, I will try it at least once.
Yesterday I was thinking about what happened and was trying to figure out what went wrong. I always try to knock the weight off the blocks before I undo the top link. If it slips or moves the top link will hold it.
What I did different.:eek:
I set the weight on the blocks = same.
Left a couple inches of slack = same.
Tried to wiggle the weight to see if it was sitting secure = same.
I disconnected the chain from the grab hook on the bucket = CHANGE - I do not remove the chain from the hook until I have backed away.
I TRIED to push the pin out from the top link connection to remove the slip hook but it was jammed so I took a 2.5lb hammer and gave it a light tap. That is when the weight toppled over with out the chain to hold it/stop it from hitting me.:(
Hard to be-leave that a 2.5lb hammer did what pushing and pulling on it did not do.:(
olthumpa
L275
May 25, 2011
1,505
Maine
I would like to thank everyone for their thoughts and for wishes me a speedy recovery.:)
Should have done it sooner. :eek:
