oil drip from muffler
TKBOTA
B6000 4x4 FEL
Feb 6, 2015
30
Long Island, NY
I had been noticing a a drop of oil off to the side of the tractor, and minutes ago I found that it is coming from the muffler. Looks like the muffler is two halves and have been flanged together. I am getting a drip of oil from the center flange. What does this mean? Is this normal or do I have big problems on my hands?
11,199
Get a picture of it and post back, not really sure what is in that area to leak oil. :confused:
bxray
Bx25d
Dec 1, 2014
712
Cleveland, ohio
Maybe you have a bad muffler bearing! :)
Just kidding!
Did you look above the muffler?
See if it is dripping onto the muffler from the engine.
Maybe valve cover.
Hope it is not exhaust valves.
Ray
TKBOTA
B6000 4x4 FEL
Feb 6, 2015
30
Long Island, NY
Can't get a good photo of it. Basically what would be the reason for oil going out the exhaust? I have not changed my oil since purchasing the previous owner said that he only put 10 hours on it since last changed (maybe I shouldn't have taken his word onit). Checked the level and it is way above the flat part of the dipstick and the numbers shown. Does anyone know what the full level should be? Could it be that it is overfilled or is it something like bxray mentioned about exhaust valves
Kurtee
BX2660, BX2680 cab, JD 2032R, Honda 5518, JD X590, JD X739
Oct 3, 2013
337
148
Nicollet, mn
The only thing I have seen like you are describing is unburnt fuel coming out the exhaust. Have you done a lot of idling of this tractor? Excess idling will cause this or I suspect that most likely you have an issue with an injector not spraying right. The fuel is not being burnt and going past the rings and out the exhaust valve. Or are the rings bad on one cylinder. I think a compression test and injector work are in order.
TKBOTA
B6000 4x4 FEL
Feb 6, 2015
30
Long Island, NY
It is possible that I don't run it up to a high enough rpm? Still getting use to it. Doesn't have a tach, I would say I am at 1/4 throttle or less, should I be running higher (say half or above) at this time of the year I've only used it for plowing and lifting snow.
Just checked the owners manual about changing the old and it mentions cleaning the crankcase, what should be used and how would I do that through a small drain plug or oil filter
bxray
Bx25d
Dec 1, 2014
712
Cleveland, ohio
Usually there is a simple marking on the stick.
Do you have the owners manual?
What model do you have?
It will not hurt or cost much to drain and refill the oil.
Mine takes 3.7 qts
Maybe it was overfilled.
Here is my manual oil stick reference.
And as Kurtee stated it may be unburnt fuel.
Try a sample on paper and a sample from dip stick and try to compare it.
And as he said you may need to open it up.
Kurtee
Oct 3, 2013
337
148
Nicollet, mn
Running at slow speeds could be the culprit. An oil change appears to be definitely in order. Oil changes are not real expensive so I think to change and run it more to see what happens. I would let it warm up some then run it full throttle or close doing what you need to use it for. Watch the oil level and muffler drips to make a judgement call. I had to look up the model to see the age. It is very possible that nothing has been done to the injection system and it needs help. Also do these need the valves adjusted? Injectors and valve adjustment are normal maintenance on other diesels.
Tooljunkie
May 13, 2014
4,150
35
Working that machine at 1/4 throttle or less isnt good. I would say closer to 1/2.
Its governed, once warm pull rpms up a little higher than you normally run. I run mine probably 2/3. if im just moving it around, its whatever rpms i choose. Gotta give it a snort from time to time.
3,082
I agree with above - dont baby the ol girl - run her not like a dog - but feed the beast !:)
11,199
If you don't have it already go to Kubotabooks.com and download the service manual. ;)
TKBOTA
B6000 4x4 FEL
Feb 6, 2015
30
Long Island, NY
I downloaded the book, but am unclear about washing the inside of the crankcase. (see attached image from the service manual)
Also the book does not show the dipstick, so I will try to get a picture of it tonight. if I remember correctly it had numbers on it up to about 6.
I have heard you should use kerosene for cleaning out the oil filter, is there anyone that could confirm this
btw, it is just as nice being part of the forum as it is owning the b6000, thanks
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
What piece of equipment did you say this manual was for?
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
80
Rocky Face, Georgia
I don't know if anybody else makes this but Amsoil makes a product called "engine flush" that you use before switching over to synthetic oil. It's as simple as dumping it in the oil and running, then drain like normal. Any crud that's inside the engine will be flushed out when you drain the oil.
TKBOTA
B6000 4x4 FEL
Feb 6, 2015
30
Long Island, NY
I changed the oil and took out nearly a gallon in a 0.53ga capacity. used the tractor for about an hour running harder than usual and did not have the drip. two days later used the tractor for snow removal about 2+ hours, and have the noticed the drip again. Not sure what it is but it is black and thick. So my overfull theory is out the window
coachgeo
Nov 16, 2012
2,459
37
Southern OH
hmmm..... when you drain the oil sniff it. If it smells like diesel fuel then certainly all the above points mentioned can cause this. So can an leaky injector(s) and few other issues.
Change oil, put RPM's up a little; as mentioned, and keep a close eye on oil level and smell etc. for further diagnosis
Tomcat
B7000 4WD, RS1(?) rototiller, Konik 125 ATV
Nov 19, 2014
557
Thailand
Run it higher than 1/2 throttle the next time you're out and see what happens.
9,118
Couple things that could cause this.
1: seal out in hydraulic pump. Check hydraulic fluid level.
2: bad injector, bad spray pattern in nozzle. Could be also something internal in the injection pump as well. Over fueling can cause fuel to get into oil.
Like coachgeo said. Give it a sniff test and check thickness as well. If oils really thin and smells like diesel, then it's getting diesel in the oil.
If it's thick and over full, then chances are it's an issue with the hydraulic pump.
If it's milky in color then chances are it's getting coolant in the oil. Usually will be obvious though and have some water in the oil.
