M95S front axle noise
Solid Rock
M95S
Feb 29, 2016
long lane missouri
I have a M95S with loader. I noticed yesterday that there is a slight grinding noise in the front wheel area, As the wheel comes around we hear the noise in the same area each time. This is the first time we have heard the noise. Fluids are full, actually we removed the fill plug to check fluids and oil flowed out. Could this be a bearing going bad and should I worry about the oil being so full.
rentthis
1,010
25
summerville,sc
The first thing to check is the wheel lug nuts. Loose wheels sound like that. You can let the oil drain on a level surface but I doubt there is a problem there.
8,606
Yes it could be a bearing, about the only way to know 100%, is open it up and inspect everything.
The oil being overfull sounds odd, could someone have filled it too full?
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Could be a temp difference in the oil. If you pulled the plug out with the oil hot the level would be higher than when cold.
hodge
Nov 19, 2010
2,945
509
Love, VA
Yep- the oil expands as it heats. So, if filled to full cold, it will come out when hot. How did the oil look? Clear and clean, milky, foamy?
