I don't post often, but I read here a lot. Thanks to those of you that willingly share your time and knowledge. It is really appreciated.
I just completed the 50 hr service on my new BX23s. How long am I able to call it "my new BX 23s" anyway? I am really enjoying it!
That said, I was surprised to see so much silicone on the strainer and am wondering if it is normal during the break-in period, or if I need to be vigilant about finding warrantable repairs before they are no longer covered.
I have a couple questions for all the smart people here in the forum:
1. Is this normal/within reasonable expectations?
2. Should I go ahead and change the SUDT2 ahead of the maintenance interval? I did clean the strainer and replace the filter as indicated in the manual.
3. I'm guessing this is gasket material. Are any of them more prone to leaking than others so that I can keep an eye out?
4. Could all that silicone have damaged my hydraulic system or worn it prematurely? What early symptoms would indicate this?
Also worth noting, and maybe it is because I think there should be after improving the flow by replacing the filter and cleaning the strainer, but there sure seems to be significantly less whine now than before.
Thanks in advance for any advice you can offer. This is my first tractor and I'm definitely still in the early phases of learning.
