Loader does not tilt
knightgang
Kubota L2950
Aug 20, 2015
192
Georiga
On my L2950 with LA 450 loader, my wife was operating and bucket got tilted all the way down and will not tilt back up (curl up). The rear 3PH hydros still work and the loader will lift up and down. I did notice fluid on the outside of the loader valve and that is new today. It is only coming from one side of the valve, I am assuming this is the tilt/curl side. I can't see it leaking, but the fluid on it is fresh today.
i have felt that the loader valve was quite worn and in need of replacement anyway, but why would it stop curling? What should I look for? Maybe a seal busted and a piece of it jammed the valve?
Thanks
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
Does it load the engine when you move the stick side to side?
Like D2Cat said, or could have blown a internal seal in one of the rams.
knightgang
Kubota L2950
Aug 20, 2015
192
Georiga
If it blew a seal in one ram, wouldn't the other one tilt it back???
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
I had the same thing when attaching loader.
DCat has it right. My connector not quite connected.
knightgang
Kubota L2950
Aug 20, 2015
192
Georiga
I will check on this today. I learned move about the events leading up to this. Seems that while my wife was working in the woods, branches and vines caught the loader handle and it was pulled with quite a force. There is a slight leak at the valve body on the tilt control side. Will check the connections first, then move to trouble shooting the valve.
knightgang
Kubota L2950
Aug 20, 2015
192
Georiga
I disconnected and reconnected the lines and the tilt functions again. However, I did notice that both cylinders are leaking and the valve body for the curl/tilt functions has leaked as well.
I will most likely break down those cylinders and have them resealed and repacked and replace the loader valve body.
knightgang
Kubota L2950
Aug 20, 2015
192
Georiga
Glad they are working, better get a splint for your wallet if you plan on buying a valve body.
Really? I am looking at one on EBay for $200, new. Price checking it against local distributor and have checked out the manufacturer website. Up to 10 GMP and 4000 psi.
I did see that Messicks wanted like $1500 for the valve body.
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
Some hydraulic shops can rebuild your existing valve for about the same amount as a new Chinese one. That might not seem like a fair deal, but all the fittings will work and you'll stay original parts.
knightgang
Kubota L2950
Aug 20, 2015
192
Georiga
This is on Ebay, but not a Chinese valve. Manufactured by Brand Hydraulics in Omaha, Nebraska.
OLD GAR
MF210, FORD 8N, BIG TEX CH18,
Aug 3, 2015
69
ZWOLLE
Or if you intend to replace the cylinders. Kubota thinks they are solid gold. OEM Seal kits aren't easy to get either. Can I post here where I finally found my seal kits for my LA272 loader?
knightgang
Kubota L2950
Aug 20, 2015
192
Georiga
I think you can post your source.
For my cylinders, there are a ton of hydraulic shops in my area where I can break down the cylinder and take it in and get all new seals.
One reason I am planning on a new valve body is because the latest linkage on mine is old and antiquated. A new valve with new linkage is a simple fix of all of those problems. Might even relocate the valve a little for better operational control.
