Left-Right brake pedal question
GaltsGulch
L3800, BX2380, and BX23S
Apr 14, 2015
38
Ranger, Ga
I have had my L3800 for going on a year now, and the left right brake pedals I have wondered about the entire time. I searched the forum but didn't see anything about the brakes. What is the purpose of the two brake pedals? They have stayed locked together the entire time I have had it but I wonder if there might be a time that being separated they would be of more use. Thanks for any insight.
Knott
2015 BX2670-1, BX2755HD Snow Blower, Farmking 4' box Blade, BX 2760A Plow Blade
Jun 2, 2015
101
Manitoba
When separated they work independently as steering brakes, fro when you turn the steering wheel & the front tires skid a bit & you gently apply the brake on the side in which you wish to turn.
DO NOT use these brakes for steering at any thing over 4 miles per hour. They are for low speed maneuvering ONLY.
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
For making ultra tight turns, the application of the brake, to the side of the direction of the turn, makes the front end swing around quicker. For road travel, keep them latched together, so you don't inadvertently swerve out of lane, when stopping, should your foot drop off one pedal. I use the heck out of them, on the L185, with turf tires...:D
Trent
B7510
Aug 14, 2015
15
Henderson, KY
Traditionally, there has been a need for tractors to turn really sharp. I assume the intent is still the same today. With my old Allis Chalmers I could turn sharp, then with the help of applying one brake, really turn around fast - almost pivoting on the one rear wheel. Hope this makes since.
Not sure if I will ever need "one brake at a time turning" with my Kubota. HST and modern power steering is pretty nice.
Trent
GaltsGulch
Apr 14, 2015
38
Ranger, Ga
Thanks for the responses. I guess I should have asked this a few months ago. Knowing that would have helped me when I was bush hogging a property we just bought. There are trees every where. I can't count the number of times that would have made maneuvering around easier. Next time I'm playing in the woods I'll give it a try.
Are the brakes only on the front axle or does is slow both tires on one side?
Trent
B7510
Aug 14, 2015
15
Henderson, KY
Imagine one rear wheel coming to a complete stop while the other rear wheel continues to travel forward. In the right conditions it can be almost like a zero turn mower. May be a bit hard on grass though.
Diydave
Oct 31, 2013
1,635
11
Gambrills, MD USA
Trent
Trent, What kinda AC did you have? I grew up on them. Some of the older ones, early B's, and C's, and WC's, had hand brakes, on either side, by the fender. When cultivating corn, procedure was to lift the cultivators, put your knees up against the straight ahead steering wheel, and yank back on the appropriate brake, do a 180 turn, and then drop the cultivators, and continue on...:D
Knott
Jun 2, 2015
101
Manitoba
Rear brakes only.
8,548
You will have front brakes on one wheel if you one use both pedals at once and you have it in 4wd. ;)
8,548
It's because the front drive propeller shaft is on the same drive as the rear wheels, so stopping the rear wheels stops the propeller shaft from turning too.
Tooljunkie
May 13, 2014
4,150
I wouldnt use steering brake in 4wd,could make for a bit of a hairy situation.
Diff will transfer power to front-aiding in turning, but breaking traction could get front to swing more than expected.
Why have a steering brake on same side as hst pedal? Supposed to use a stick to operate one or the other?
Never could understand that.
hodge
Nov 19, 2010
2,945
509
Love, VA
If traction is equal, you can have both front tires braking. They, and the differential, have no idea what is going on in the back. If the drive shaft slows down, regardless of the cause, they slow down. If traction is equal at both tires, they both hold the tractor back.
Because of the differential, the only way that one tire can go faster (hold back less) is in a turn (where they travel different arcs/distances), or if one tire speeds up or slows down, or rotates the opposite direction of the other tire.
8,548
Yes true, it just usually equates to one wheel slowing or stopping and the other slipping or spinning. ;):D
TripleR
Sep 16, 2011
1,911
SE Missouri
I grew up row crop farming and the split brakes were essential for improved maneuverability, but have yet to find a need for them on our CUTs, so the brake arrangement on my L5740 is a non issue for me, but the manual indicates use of the cruise control to operate with split/steering brakes.
On L40 Series, the brakes are closer to center-line than the L30 or standrd L, so it is quite easy to use your left foot.
The new L60 Series comes without a clutch and brakes on the left like pretty much all the rest, so I am guessing there will be a natural transition to this configuration on all models over time.
hodge
Nov 19, 2010
2,945
509
Love, VA
With the hydro pedal on the same side as the brake pedals, I haven't been able to contort enough to use the brakes for steering. Tractors still have it, but I imagine that few use them separately.
TripleR
Sep 16, 2011
1,911
SE Missouri
It is harder on some Kubotas than others. My son could on our L5030, but I could do so only by using the cruise control or my cane.
When I got my L5740, I was able to do so quite easily, but never use them.
I still use them on some of our geared UT and Ag models in the woods, but never on a CUT.
2,781
Hodge,
funny you mention that - I always thought it was "strange" that you place dual brakes on the SAME side as the "movement pedal"
on the old ford N - I used the brake a lot on hard turns - worked perfectly.....
hell I am glad on the BX series THEY moved the brake to the left rather than keeping it on the right, in deep thought situation I like my foot "on the brake" and my other foot giving a little goose!:D
sheepfarmer
Nov 14, 2014
4,441
677
MidMichigan
Thanks NIW, TJ, Hodge, it is slowly getting clearer how this thing works. Wish I could see the pieces taken apart, just not mine! :D
boz1989
B2910 fel 60 mmm, Land Pride rb1572
Jun 10, 2015
269
Portland, MI
On other tractors I have used the individual brakes to stop the wheel that is spinning in the mud. Now that I have a working diffy lock, I use it instead.
