I have an early 80s model l245dt that I am needing a front loader for. currently it has a front pivoting blade and a trencher on the rear. I am wondering how hard its going to be trying to find a loader that will fit or if I should just trade it in at one of the local tractor dealers for one that already has a loader.
There are some things that do need to be repaired and or replaced
NEEDS:
-Wiring harness front and back
-Key switch
-Plug plugs and or entire glow plug circuit
-Front axle hubs have play and leak gear lube
-Front blade cylinders leak and need rebuild. possibly new control valve as well.
-New exhaust after manifold
-could use 1 new rear rim and both front tires due to dry rot
-trencher could use new sprockets
Most of that stuff I can do myself its just a time issue I run into. I like the tractor but I definitely wouldn't go any smaller and do wish it had a live pto. need the front loader as we are bring the horses we have to the house instead of boarding them.
tractor would be used for the farm work as well as snow removal, running a manure spreader and possibly a plow or tiller. what do you guys think? and how much do you think I could get for the blade and trencher?
NEEDS:
-Key switch
