L ladyyarddog New member Equipment Kubota BX1850D Jul 17, 2016 3 0 0 Arlington, TX Jul 17, 2016 #1 Starter won't engage. Battery, starter, key switch, seat switch all good. Is there a fusible link or another safety switch somewhere? Last edited: Jul 17, 2016
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 10,973 2,827 113 Bedford - VA Jul 17, 2016 #2 ladyyarddog said: Starter won't engage. Battery, starter, key switch, seat switch all good. Is there a fusible link or another safety switch somewhere? Click to expand... Tell us how you know all those other parts are "good?" Yes - there are fusible links - not sure without digging if/where yours is located. YOU have a volt/ohm meter? If so - check voltage @ starter while key is turned. report back with any news
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 33,399 8,707 113 Sandpoint, ID Jul 17, 2016 #3 Safety switches are usually the first cause of a no start. Check PTO levers (in off position) and HST pedal (centered).
L ladyyarddog New member Equipment Kubota BX1850D Jul 17, 2016 3 0 0 Arlington, TX Jul 18, 2016 #4 85Hokie said: Tell us how you know all those other parts are "good?" Yes - there are fusible links - not sure without digging if/where yours is located. YOU have a volt/ohm meter? If so - check voltage @ starter while key is turned. report back with any news Click to expand... Checked all parts with vom meter. Finally found HST switch hidden behind right rear wheel needed adjusting. Starts every time now. Thanks for responding.
L ladyyarddog New member Equipment Kubota BX1850D Jul 17, 2016 3 0 0 Arlington, TX Jul 18, 2016 #5 North Idaho Wolfman said: Safety switches are usually the first cause of a no start. Check PTO levers (in off position) and HST pedal (centered). Click to expand... Yup, finally found HST switch hidden behind right rear wheel that needed adjusting. Starts every time now. All is well. Appreciate the response.
