Kubota BX1850D won't start
ladyyarddog
Kubota BX1850D
Jul 17, 2016
Arlington, TX
Starter won't engage. Battery, starter, key switch, seat switch all good. Is there a fusible link or another safety switch somewhere?
2,828
Tell us how you know all those other parts are "good?"
Yes - there are fusible links - not sure without digging if/where yours is located.
YOU have a volt/ohm meter? If so - check voltage @ starter while key is turned.
report back with any news
8,716
Safety switches are usually the first cause of a no start.
Check PTO levers (in off position) and HST pedal (centered).
ladyyarddog
Kubota BX1850D
Jul 17, 2016
Arlington, TX
Checked all parts with vom meter. Finally found HST switch hidden behind right rear wheel needed adjusting. Starts every time now. Thanks for responding.
