I think I would start by checking the fuses and making sure the HST is in the neutral position. Is your question how to get it started again after it dies?Our 3350 blade hit and object and died. Sheepfarmer, do you have any suggestions?
You check the main fuse down by the starter?I have a 3350 also. Yesterday was driving and died. Lost all dash power also. So I read this forum. Checked all fuses. None are blown. So next assumed the switch for the pedal under the tractor was broke. Went and bought a new one installed it and still no power. Cleaned the ground. Battery has 12.6 volts. Any sujjestions.
I don't see a fuse there. Only a fuse box by the alternatorYou check the main fuse down by the starter?
Ya there all goodSorry they moved them on that model, There is another fuse box with 2 big fuses beside the battery.
