heres what happened. I was box blading and the tractor died. I turned the key to restart and there was no dash light nothing except the fuel pump was ticking. any help would be appreciated.
First up check fuses, if you have no dash lamps you probably have no power to the OPC controller which will inhibit your start.
For the benefit of others down the track, which fuse? One also needs to try to work out why the fuse blew?jat said:It was the fuse... THANKS A TON..
Mine is a 2013 and the ECU 5 amp fuse blew today, twice. Tractor had just finished a regen cycle, regen light went out. I idled the tractor for a minute to cool down turbo, then shut down.Mine keeps blowing that fuse off and on and I wanted to know if anyone else has the same problem and what it might be.
Very good info as I am having the same issue with my 2014 B3350.Further searching on-line had other's with the same problem, and the cause being the HST Pedal Switch. Ordered a new one, and in the interim, wanted to get tractor back in service.
I removed the switch from the bracket, letting it hang down, removed one of the mounting nuts. Determined that 1/2" male pipe thread will "start" into the removed nut. Used a PVC 1/2" threaded end cap that depressed the switch plunger and then threaded onto the switch male threads to stay firmly in place - good fix and easy too! The I used some hook and loop tape to fasten the switch to a fabric sleeved nearby pipe. I needed to keep the metal parts of the switch insulated from tractor ground, as there is apparently an intermittent short in the switch that was grounding to tractor frame and blowing the 5 amp "Panel ECU" fuse. Tested fine.
Are you sure it was the fuel pump making the noise.heres what happened. I was box blading and the tractor died. I turned the key to restart and there was no dash light nothing except the fuel pump was ticking. any help would be appreciated.
Our 3350 blade hit and object and died. Sheepfarmer, do you have any suggestions?Were all the lights normal before it died? Was the tractor in "inhibit regeneration" mode? Could you have bumped the pto lever when you got off, or did you not move before the first time you tried to start it? Could the engine have stalled because your blade hit an immovable object? Any more information you have about the tractor would help.
100td I have a wiring diagram in the wsm for the 2650/3350. Will post if I can extract from pdf. The complete wiring diagram is 11 by 17 and will not reproduce.
