kubota B3350 died and wont start
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
Our 3350 blade hit and object and died. Sheepfarmer, do you have any suggestions?
I think I would start by checking the fuses and making sure the HST is in the neutral position. Is your question how to get it started again after it dies?
Chrissweez
B3350
Mar 16, 2022
Manitoba Canada
I have a 3350 also. Yesterday was driving and died. Lost all dash power also. So I read this forum. Checked all fuses. None are blown. So next assumed the switch for the pedal under the tractor was broke. Went and bought a new one installed it and still no power. Cleaned the ground. Battery has 12.6 volts. Any sujjestions.
9,281
You check the main fuse down by the starter?
9,281
Sorry they moved them on that model, There is another fuse box with 2 big fuses beside the battery.
9,281
DO you have the WSM, AKA service manual?
Own a test light?
Your next best bet is to start probing main wires to find out where your loss is at.
you could have a bad ground so check all of those connections too.
