Kubota Transmission Filter & Fluid Change
Orange Man Good
MX5400 HST
Mar 1, 2021
41
9
Somewhere Alabama
Hey guys, I am new to the forum and wanted to say hello as well as ask you for your opinion. I was reading through the operator's manual for the MX Series tractors and noticed that Kubota is calling for the transmission filter and fluid to be changed at 50 hours as well as every 200 hours thereafter. Are any of you out there changing it this much?
3,014
Orange - glad to have you, great folks you'll find here.
With a machine that cost that much - I would follow the ol book! And I would use NOTHING but the S-UDT2 and Kubota filters! I know that may be $$$ to do - but the thought of having to fix something in the hydraulic system would end up costing dollars over pennies!
Reactions: 6 users
Creature Meadow
Sep 19, 2016
1,065
140
Central North Carolina
Welcome to OOT from NC.
I have an L4600 smaller cousin to yours.
I do stick with the recommended schedule except for motor oil changes. I change this every 2 years regardless of hours.
I change my air filter yearly, friend told me if it can't breath it will die! I do remove the outer filter after using it in dusty conditions and blow it out.
The hydro oil change cost me just shy of $300 for the SUDT2 and Kubota filter. I also do the front end at the same time using the SUDT2.
I figure the cost for maintenance especially if done by me is small compared to major repairs or worse case replacement.
Best of luck.
Jay
swpflipper
MX5400 HST, LA1065 FEL, HR2572 box blade - S30 flip Screen
Nov 3, 2020
100
54
Arizona
Yup. I just did my 50 he on my MX5400
I will stick with the recommended service intervals.
I use kubota fluids and filters for hydraulic system.
Orange Man Good
MX5400 HST
Mar 1, 2021
41
9
Somewhere Alabama
Thanks for the replies and opinions that have been offered up.
Can any of you guys explain to me why the service intervals are so short? I know with John Deere they don't require the trans fluid to be changed until 1200 hours or 3 years.
Creature Meadow
Sep 19, 2016
1,065
140
My L4600 shows 400 for hydro oil it is a gear drive, otherwise it is 200 hours if it were hydrostatic.
Not familiar with the MX but if gear drive seems it would be like mine, 400.
Orange Man Good
MX5400 HST
Mar 1, 2021
41
9
Somewhere Alabama
Ok so I am a little confused here and maybe you guys can help clear it up. If you look at the maintenance schedule that I uploaded for the MX series, Kubota is showing that the transmission oil should be changed every 400 hours. However, they are also showing that the transmission oil filter should be changed every 200 hours. So are they saying to change the filter independent of the fluid?
5,506
2,217
for the last 2 years of my employment at the kubota dealer, there were several instances where the warranty department at Kubota had asked for service records, while submitting a warranty claim. Also, they've gotten anal about fluid analyses as well. If no record,s no pay, meaning customer gets to eat the cost of the repair. Or if fluid analyses come back with contaminated fluids they can and have denied warranty coverage; as the root cause of failure was not due to manufacturing defects; rather something that was out of their control. Just putting it out there for what its' worth (maybe nothing?)
7,453
Orange Man, welcome to the forum. The 50 hour fluid change seems early, but the purpose is to clear out any "casting crumbs" from manufacturing that may be hanging around! Just cleaning everything up for a nice long life.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,646
2,239
WestTn/NoMs
I read 200 hr for the hydrostatic HST filter (if you have HST) and 400 hr for the hydraulic filter and fluid.
Borane4
M4-071
Dec 16, 2020
105
So if you do your own regular service?
My dealer said to record that you did the service and keep any receipts as proof. Note from gas receipt experience....if you want a cash register receipt to survive as a record, you need to scan or make a copy of it. They fade all the way to blank over time.
Orange Man Good
MX5400 HST
Mar 1, 2021
41
9
Somewhere Alabama
Ok so I put together another pdf file of the maintenance schedule along with the correlating sections about the transmission filter change at 200 hours and the transmission fluid change at 400 hours. The operator's manual is contradictory. On the maintenance schedule it shows to not change the transmission fluid until 400 hours. However, on the 200 hour service section it says to drain the transmission fluid when changing the filter. Draining fully synthetic hydraulic fluid at such a short interval also makes no sense given the fact and expectation that synthetic oil is supposed to extend drain intervals and service life of the fluid not shorten it.
2,815
Yes the filter can be changed more frequently than the fluid. So filter every 200 and fluid every 400 sounds reasonable.
Draining the fluid into a clean container to change the filter is also a reasonable process to keep the fluid from draining out the filter housing whilst you retrieve the filter off the bench if you forget to have it in hand or don’t want fluid polluting the ground since it will leak while the filter is removed.
Then use fluid for another 200 hours.
Orange Man Good
MX5400 HST
Mar 1, 2021
41
9
Somewhere Alabama
Another thing that doesn't make any sense is why Kubota is requiring the transmission filter to be changed half way through the service life of the transmission fluid. Why wouldn't they call for both to be changed at the same time like a engine oil and filter change?
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,646
2,239
WestTn/NoMs
We don't know exactly what tractor you have. If it's a hydrostatic HST, I think you have 2 filters, one for the HST and one for the hydraulic system. But they share the oil I think. Non HST only has one filter. Notice that the HST tractors change both filters at 50 hrs.
I think the service procedure says drain the fluid because it pours out when you remove the filter. Then reuse it (except every 400 hours). But some folks have figured out ways to change filters without draining the oil.
It's a little confusing because it's written to cover HST and non-HST tractors even though they have different intervals.
BTW, it would help if you edit your profile with your full tractor model number.
