Gas in my diesel
Rgettman
Ofallon MO
I accidentally put gas in my MX 5200
It seems to have impacted the hydraulic pump seal and I’m not sure what else. What can I expect to hear from the shop?
6,415
Three sentences. Can't tell you what to expect from a shop with limited information.
Gas in fuel tank has no impact on hyd pump seal.
Did you run engine after filling with gas? If so how long? How much gas to diesel ratio?
You took it to a shop?
Drain gasoline and fill with diesel.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
With a common rail engine that’s had gas run through it you can expect to hear the high pressure fuel system needs to be replaced. The high pressure pumps dont tolerate gas.
Rgettman
Ofallon MO
I ran it twice for about two hours each. After the second time the engine would start but not stay running. The hydraulic issue is from large amounts t if extra fluid in crankcase and low fluid when hydraulics checked.
8,460
I think you're not going to like the answers they give you!
Do you have KTAC insurance?
3,135
Trying to understand why you think adding gasoline to the fuel tank would cause issues with the hydraulic system…
Edit: unless you meant you added gasoline to the hydraulics instead of the normal hydraulic fluid…
5,131
It is impossible to make any sense of these comments.
If you put a significant amount of gasoline in the DIESEL FUEL tank, and ran the engine twice for two hours each time, your diesel engine is very likely now toast!
I am actually very surprised that it would run with a gasoline diesel mix, for an aggregate of 4 hours, unless you added only a relatively small amount of gas to a mostly full diesel tank.
OrangeKrush
Nov 15, 2020
1,044
515
Indy
No answers.. just interested in the outcome..😐
Flintknapper
L2350DT
May 3, 2022
1,902
2,392
Deep East Texas
I'd be very surprised if anything but some sad news is forthcoming.
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
544
309
Mandeville Louisiana
As D2Cat said drain everything, remove all fuel lines, flush throughtly, new filter, fill with fresh diesel, properly vent the entire system. and cross your fingers and give it a shot. If you're lucky, then change the oil and filter and address the seal issue. One thing for sure you'll never make that mistake again.
5,415
2,106
probably 4 new injectors, supply pump assembly, lift pump assembly, rail w/pressure sensor assembly, and whatever else.
As Fordtech said, common rail engines do not tolerate anything but diesel, includes water. That's why it's imperative to make sure your fuel is clean, filtered, diesel-and also imperative to keep the filters and separators clean.
Did quite a few Standard L series injectors and pumps. Ain't cheap either. Kubota denied at least one after having done analysis on the fuel as well as the aftermarket filter. Owner had to fork out about $4800.
Quick
B2601, LA435, BH70, LP SGC0554 Grapple, LP RB1672 Rear Blade, King Kutter 60" BB
Sep 23, 2021
142
249
St. Clair, MO.
Trying to figure out where OP put this gas. Doesn't make sense.
  • "Extra fluid in crankcase"
  • "Affected the hydraulic pump seal"
  • "Engine won't stay running"
3,344
This might be a hit-and-run….
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
It's a "one and done" (methinks) just to get you guys riled up.
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
Rgettman
New member · From Ofallon MO
Joined Feb 21, 2017
Last seen Monday at 3:02 PM
Hmmm, OK, well then, maybe not Dusty !
The post was certainly very confusing to say the least.
Either English is not this person's first language (that's fine) or maybe alcohol was involved?
Just sayin'...I would normally TRY to help (to the limits of my ability) but had absolutely nothing to offer this time as it was so convoluted.
58Ford
BX23s, LA340, BT603, RCR1248, PFL1242, STB1072
Jan 1, 2022
248
204
SW Washington
If I did that to my tractor I’d for sure be drinking!
troverman
Jun 9, 2015
1,178
263
NH
Gas in the fuel tank won't affect the hydraulic side. It will ruin a modern electronically controlled common rail diesel like the MX5200 in a hurry. One thing I've noted is that Kubota has recently changed the water separator design on all the MX series tractors, and perhaps all the tractors. The separator is now larger and instead of the simple float against a red line on the clear housing, the separator has a sensor in it and a WIF light on in the cluster. I'm pleased with this because most folks run dyed diesel, which is red, and makes the float against the red line very hard to see. However, it may be indicative of a lot of problems with water in the fuel ruining the high pressure fuel system. Gas in the diesel likely means an entirely new fuel system and a complete fuel tank cleanout and new filters. Running four hours with any volume of gas in the tank would cause the high pressure pump to lose lubrication and start spitting pieces of metal downstream into the injectors and pressure control / volume valves. And probably return some to the tank.
Mark_BX25D
Bx25D
Jul 19, 2020
1,781
1,301
There's another possibility. I have noticed that some people seem to think their job is to throw out words and then figuring out what they mean is everybody else's responsibility. It appears some people were never taught to think about what they are saying and make an effort to communicate rationally.
I recall a post on another forum that had literally two words in the title and two words in the post. Not particularly useful!
And then he was offended when people asked questions, trying to understand so we could help him. His second post was his last post and was also two words (which I will not repeat).
