FEL float ???
Truckedup
23
Ontario NY USA
Do any Kubota front end loaders have a "float" position ? A know it all friend said all front end loaders have this...I know my after market Allied FEL doesn't have a float position. I operated many loaders, including articulated, but never noticed about a float position . Maybe I don't pay attention...:D
TripleR
Sep 16, 2011
1,911
SE Missouri
We have four Kubotas and all have float, so did the one we traded in for the last new one.
2,897
Truck,
Take you handle and throw it all the way forward, if it has float, it will click and stay, there is a detent that allows the lever to stay forward. Bucket will rest on the ground.(Dont do it with it up:))
Burt
Mar 24, 2012
337
Goldendale, WA USA
Truck,
Truck,
Put the loader on the ground in the position you want it to float. Then, push the handle up and you are in float position.
What tractor do you have?
Burt
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
Yup, my 2014 l3560 does. On the other hand my 1950 ford 8n Wagner loader does not. Wonder when they invented them? It is so handy.
Truckedup
23
Ontario NY USA
Truck,
Burt
B7100....Allied brand front end loader.....Yes it has a detent....I dropped the bucket onto to ground then pushed the lever all the way forward and it stays there....Thanks....
djm1204
L4600 HST, FEL, Root Rake, Land Pride Grapple, Two way radio
Aug 11, 2014
84
Dunnellon, FL, USA
Not that you asked, but if you have a 3 point hitch on the rear - most recent year tractors also have a "float" position for the 3 point hitch.
I used the FEL float position all the time - both with my bucket and the grapple, open and used as a rake.
Burt
Mar 24, 2012
337
Goldendale, WA USA
Truck,
Great! Floats my bucket!
Burt
Kennyd4110
Vendor Member
Sep 7, 2013
1,419
745
Westminster, MD
www.boltonhooks.com
Um...the 3PH naturally floats since there is no downpressure on it, no "position" required.
9,582
UMMM :rolleyes:
Most, like 99.9% of tractor have always had 3 point float, only the largest and oddest models have down pressure for the three point. ;)
clay45
L2050DT, TSC 5ft Rake, Tartar 5ft rototiller, TSC Middlebuster, TSC CarryAll
Feb 6, 2015
279
SC
My loader manual says it has it but when I try it it just lifts the front wheels up.
I know squat about this stuff. Is there a valve to turn or switch to throw somewhere? A quick run thru the loader setup revealed nothing.
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
You have to be quick, or yes it does lift the front up. So put the bucket down on the ground and then push the joystick forward really decisively. You should feel a little click as it goes past the detente.
tcrote5516
BX1860, FEL, 50" Front Blower, Heated Cab, 6' blade, 3pt carry all, 3pt hitch
Sep 2, 2014
482
Southern New Hampshire
Or push it up as the bucket is dropping to the ground so you get the stick in the float position before the bucket contacts the ground and dont have to worry about it lifting the tractor.
My BX also has a float on the curl dump as well that I would imagine all must have. This is usefull when doing gentle grading.
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
My LA524 on my L3200 has float, love it.
My D-17 with a Wagner front loader does not, but will once I change out the control valve system. As for why they didn't come that way, the float option used to be very expensive on control spools, but now it only adds a few bucks.
We are actually very spoiled in what we have available to use on our little Kubota's in these later generation machines.
