Essential tools in the internal toolbox?
4,604
Pliers, screwdrivers, extra fuses, hitch pins, lynch pins, adjustable wrench, fence pliers, hammer if it will fit.
Chain saw
Lunch
Fifth of whiskey (for when it's cold)
Mechanics wire
Butt splices
Wire strippers/crimpers
Vise grips
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
Chain saw
Lunch
Mechanics wire
Butt splices
Vise grips
What, no duct tape? Not near enough redneck in that... :D
mendonsy
B7500HST/LA302
May 28, 2012
339
19
Mendon, NY
WD40 and duct tape!
If it's supposed to move and it doesn't use the WD40.
If it's not supposed to move and it does use the duct tape.
5,180
Pliers
Screwdriver or two
Adjustable wrench
and few fitted wrenches, common size is 10mm, 12mm, 13mm, 14mm
If you have room for one make it the 10mm.
Rap them in a rag to keep them from rattling. :D
Alexisferos
L-1501 DT
Oct 24, 2013
245
Greece
in mine i have
Adjustable wrench
Pliers
10mm-11mm, 12mm-13mm, 17mm-19mm
Utility knive
Work gloves
double side screwdriver
one extra hitch pin
two linch pins
and two hair pin clips
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
Pliers
Screwdriver or two
Adjustable wrench
(So, no comments about how I go from redneck to elitist here... just go with it!)
RAG? What kind of Kubota owner are you? Custom cut foam padding my friend, and while we are at it, carnuba wax!
Heathens I tell ya... heathens! :rolleyes:
BadDog
B7100D TL and B2150D TLB
Jun 5, 2013
579
Phoenix, AZ
And the one tool you need will not be in there and you will be 3000' from the shop!:(
Truth...
That little box isn't big enough to hold more than a motorcycle kit. I would suggest a rag, adjustable wrench (10" if it will fit, 8"?), channel locks (again, good size if possible). Those are the type things you usually need. Maybe the biggest flat head screw driver you can fit, but not many screws, more for prying/digging.
2,852
I have come to one conclusion no matter what you have in the tool box,,,, What you need is back in the garage;)
2,240
ShaunBlake
Dec 21, 2014
899
My B6001 with D950 engine have an small internal toolbox in front of the gearbox...
Anders, I think it would have taken me a year or so before noticing that little cubby-hole. Gotta give you a big Thanks! for posting this.
I can't see inside mine but I took a snapshot and my phone did a remarkable job of enhancing the image... sadly! Looks like mine isn't very well joined; tools stored in it will have to be plastic or disposable. <sigh>
Reached in and found a pretty rusty oil filter wrench. Reached in again, and found... :eek:
Not fabric, but no nest... <shrug>
Now I don't have to keep clevis pins and clips in my pockets, but will have to get some little balloons or snack bag 'zip-locks'.
2,240
I had a plastic/fake leather pouch lying around- the kind that the tools for the jack on a small car are stored in- rolled my tools up in that, and then stuffed it in the box. Should keep 'em from rusting away.
