Can you figure this one out? Answer post 12!
Jpatrick
BX1850, L210, Various 3 point implements
Apr 4, 2017
100
Buckingham, Pa
There are a lot of smart and experienced folks here. See if you can figure out this puzzle, based on the information I give you in the next paragraph.
A few days ago I needed my L210 to haul some firewood. It was about 20 F in the barn, so I did what I always do when it's cold. I pointed the 80,000 btu space heater at the tractor engine block and ran it for about 40 min. When I came back from loading the trailer, I found a big puddle of liquid beneath the tractor.
Here's what you need to figure out.
1. What liquid was it?
2. Why and how did it get there?
Here's hoping someone nails this one. If not, I will explain all in due time.
NHSleddog
B2650
Dec 19, 2019
2,149
1,823
Southern, NH
Re: Can you figure this one out?
You drove over the heater leaving the barn and all the fuel ended up on the ground?
4,066
condesate from the gases the heater gave off hitting the cold tractor and condensing from water vapor to liquid H20
4,392
The heater got the fuel tank too warm and the rust hole started leaking. Diesel on the ground. Or, maybe it was a melted fuel line.
BAP
Dec 31, 2012
2,531
670
At 20 degrees, why did you need a space heater on your tractor? Not that cold.
KennysNewFarm
MX5800
Dec 28, 2017
220
Missouri
Just like anything metal that sits in the cold. Heat displaces the cold and condensates causing more or less a defroster. My tools in my work truck when left overnight and brought inside to a job the next time develop condensate all over them. Then after they warm completely up the water evaporates. My guess is the inside of the tractor could do the same causing water to develop in the oil. After running the machine up to operating temp it should however evaporate.
motionclone
May 4, 2018
1,398
992
Maine
coolant, popped a freezeplug
sheepfarmer
Nov 14, 2014
4,444
661
MidMichigan
Coolant from the overflow tank.
Jpatrick
Apr 4, 2017
100
Buckingham, Pa
I was afraid I'd popped a frost plug, but that wasn't it, thankfully.
Jpatrick
Apr 4, 2017
100
Buckingham, Pa
D2Cat. right fluid, wrong reason, but close enough.
Here's the answer.
The fluid was diesel fuel. I filled the tank full of fuel the night before, and when I heated it up, the tank overflowed. How much? I figure in the range of 200-300 ml. Some detail given below.
From Stack Exchange, The thermal expansion coefficient of diesel fuel is .00046 per degree F. So, the diesel fuel in the tank will expand when heated. Figure the temp of the fuel rose from about 20 F to about 50 F, and that the fuel tank capacity (from the service manual) is 6.3 gal (24 liters) So, .00046 x 24000hml x 30 F = about 330 ml
Now it's true that the fuel tank will expand when heated as well, so if we want to be really strict, we should consider that. From Engineering Tool Box, the thermal expansion coefficient of steel is about .000011. That's less than the value for diesel fuel. While we can't disregard the tank expansion, that information makes it clear the tank will overflow, and that's what happened.
So, the lesson taught here is that I shouldn't fill the tank full to the top when it's cold.
Mak65
L2501 HST
Apr 25, 2019
112
65
TX
You melted a hole in the lower radiator hose.
I see I missed the answer post.
Dvan
Kubota L2501- LA525 Loader- RCR1260 Rotary mower- BB1260 Box Blade- RB1672 Blade
Sep 28, 2019
26
19
Parker, Colorado
Your dog discovered a nice warm place to relieve himself.
Jpatrick
Apr 4, 2017
100
Buckingham, Pa
This tractor is cold blooded. She really doesn't like to wake up it it's colder than 50 F. Takes about 90 sec of glow plug at that. More modern units like our Bx don't take nearly as much to get going.
3,845
This is why fuel oil delivery trucks now utilize temperature compensating meters and registers on the delivery hose. In the old days, the trucks were filled in the late afternoon, and then kept in a warm garage, so the fuel would expand, and was still warm for most of the deliveries. You were paying for the "expanded" fuel, and it would shrink after it was in your tank for a few hours.
dsims
BX2380 60"Drive Over/SSQA Loader
Feb 23, 2019
35
Clear Lake, IA
We've had that happen where I work. Our fuel barrel is outside, but our snow plows stay in a heated building when not in use. If someone tops off a truck too much then puts it inside, it will overflow overnight. Most of us have learned to leave them down a little bit. When the truck holds 200+ gallons, there is no reason to squeeze in that last gallon anyway.
2,825
How the hell much is 200/300 ml ? You are from Buckingham PA USA, not Buckingham England
ehenry
BX22, FEL, BH, 40" pto tiller, 42" Bushog Squealer, pto hole digger, B7300 w/60"
Mar 25, 2014
356
88
Canton, MS
What skeets said X10 ! ! ! ! !
