My bad, filled it up with diesel. I promise not a blonde, just too much going on with this running back and forth between Houston and Arkansas.
It starts, but will die immediately. Has a fairly new fuel filter. Also, If the horn works, is that an indication the regulator is ok?
How long did it run when the wiring started to smoke?
Once you flipped the battery - how long did it run? Post 9 you said it ran a while.....
when the filter was changed - did the lines get bled until bubble free?
SO what has changed between that time and now - runs and cuts off?
DO you have a volt/ohm meter? If not, pick one up, very cheap ($10) - can get one at walmart
- best test is to take meter, set on DC voltage and read the battery at rest, should be 12.5+ , THEN start and run - rev up some (if possible) and test, IT should go up and read 13.4+ volts.....(if it does NOT change, or go up - then your wiring is toast, or VR is
- the horn might work with any voltage from battery or bad VR
Will not tell you if VR is cooked.
