New member B2650 question
obrut
2013 B2650
Jun 29, 2024
12
14
Valparaiso IN
Just bought a 2013 b2650 today. I had to drive 3 hours to get it. Ran great the entire time I tested everything at the guys house. I get home and after about 10 minutes it stalls out and runs rough when I restart it. Seems fuel related, I add a few gallons of diesel but no luck. Did I adjitat the fuel or something? Not sure what to check first. Thanks for any help.
3,091
Welcome to the forum
I would start with the fuel filter - I would replace it.
Watch this video and see if it helps
7,718
Did it idle down and then die, or shut off quickly? Any other clues? Maybe unscrew the fuel cap and see it it runs longer.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,750
4,635
PEI Canada
I'm thinking the three hour trip stirred up a lot of sediment. Definitely start with the fuel filter. Let us know how it works out.
11,285
It idled down then died.
Fuel is being cut off, probably some crud in the tank.
Replace filter, if that doesn't fix it, you'll need to dive into it further.
5,164
The seller might have done it and forgotten to tell you so. If it were mine, I would get one of those self-starting siphon tubes and start siphoning the fuel out of the tank. Put a piece of cheesecloth on the end where the fuel is going into the tank you are draining into. If you find any crud in the cheesecloth then that will tell you there is dirt in the tank. It might be something large enough to block the line, and that will require the removal of the tank to get whatever is blockage is.
3,161
No it didnt, i didnt know there was one, is that the problem?
There may be some confusion here…
Look for some sort of valve (petcock) between the tank out and the filter. I don’t see one on the illustrated parts list but it might have been added to shut the fuel off.
or
Look for the method the tractor is shut down. Is it turn key off and tractor dies or some lever is moved and tractor dies? Is that method working correctly?
The overall issue seems to be fuel supply to the injection pump so start looking at how the fuel supply gets fuel from tank to the injection pump and see how much fuel is available by removing the ends of fuel lines to see if you have good fuel flow. It is messy if you are not careful about how you do it (drain into clean bucket, be able to stop the flow with tube clamp pliers…)
You can also see if the tank is not venting properly by leaving the fill cap loose. But keep something on the tank fill so debris doesn’t get into the tank.
obrut
2013 B2650
Jun 29, 2024
12
14
Valparaiso IN
Thanks for the reply guys, I won't have achance now to look at it until late tonight, but I will have all day tomorrow to work on. I'll post pictures and results of what I find.
obrut
2013 B2650
Jun 29, 2024
12
14
Valparaiso IN
Update, it runs. Bought a new fuel filter and orings. Siphon the diesel from the tank, and it looked pretty clean. A couple of small pieces of debris in the paint filter i used to filter the diesel before going in the fuel can.. Pulled fuel line from the tank to the filter housing, and it was just trickling out. I blew air through it, and then fuel was pouring out. Something is in the tank. I replaced the fuel filter and started up, and it runs.
S-G-R
Jun 17, 2020
1,750
4,635
PEI Canada
Great news! Glad it was a simple fix.
11,285
Plan on pulling the tank and cleaning it completely or that clog will return, and usually at the most inconvenient time.
obrut
2013 B2650
Jun 29, 2024
12
14
Valparaiso IN
Just used it to move all the attachments around and it's running great. The only other issue is the HST pedal does not return to center. I checked all linkage and it looks cleaned, lubed and move freely. Looks like there is a hydraulic cylinder, small shock, connected to the linkage, is that for centering the pedal?
3,091
That is somewhat like a shock absorber - when you release the pedal, it slowly returns to neutral rather than stopping you abruptly. Believe me when I say some older models did NOT have that and if you raised your foot off the pedal it would jerk you forward or backwards violently!
As wolfman said - that plug in the tank will surely come back - so be prepared to remove it sometime WHEN you have the time.
obrut
2013 B2650
Jun 29, 2024
12
14
Valparaiso IN
I will definitely pull the tank as soon as I have a chance. Hopefully it's not to hard to get out. I changed the engine oil today, T6 rotella 5w-40 and a kubota filter. I also fixed the pedal not returning to center. It was the shaft that the pedal pivots on. It was dirty and a little rusty. I cleaned it up and coated it with fluid film and now it's super smooth and returns to center!
