Generator Cord Receptacle
7,118
Know there’s a lot of guys more savvy than me at this stuff.
I had a 50 amp feed put in for my generator.
The box on the outside of the house came with a 15 foot cord, which has proven to be too short for my situation.
I got a 50 foot cord, and realized it doesn’t have the center pin on the receptacle like the 15 foot cord has.
I didn’t wire the box, but I think the center pin is just for alignment, and is not a conductor?
The pins in the box are two hots and the neutral; the ground is around the outside perimeter of the plug and receptacle?
15 foot cord.
50 foot cord.
bearbait
Dec 9, 2011
4,159
912
New Glasgow Canada
15 foot cord.
50 foot cord.
Yes RCW I believe you're right but I can't say I've ever seen one like that, almost looks like that centre post would pull out if you tried.
7,118
Thanks bear - I do see a small metal contact in the box’s pin, but the obvious ground to me is the conductor on the outside of the receptacle.
There is no metal conductor on the cord side plug.
7,118
Just for giggles, I started to make a center pin. Still needs work, but close to fitting.
9,776
The center pin is just a guide pin, no electrical or ground connection involved.
DO NOT add a pin, it's not needed, and it's not safe to add in.
CAPT Seabee
Grand L5460
Dec 28, 2022
91
91
Bonners Ferry ID
Look closer. The center pin isn't the issue. Check out
It's a 4 wire with the ground on the side edge of the plug. Your picture shows this on the package label. If the ground connector isn't there, it needs to be returned as a defect.
9,776
Your not in California, you don't need it! ;)
7,118
Thanks Wolfman -
I saw that CS designation, but could not find it’s derivation.
For folks in the future, the common references are CS6375 and CS6364. Per the video, the CS reference is California Standard.
For us “normal” folks, the configuration is SS2-50, which is compatible with both CS versions from what I can determine.
While shopping for a generator and appurtenances, I did notice some were “50 state compliant” where others did not.
What NIW pointed out is that California compliance…..👍
7,118
The ground is there. My picture didn’t capture it as it was on the other side of the receptacle.
7,118
Somewhere on it probably says: "Known to cause cancer in the State of California".
Hell.....everything else does. ;)
One of our identical twin daughters lives within 300 yards of the Monterey Bay beach.
The Mrs. visits often. I’m only good for occasional visits.
Way too many people for me, and I don’t travel well in general.
It’s remarkably expensive to live there. I can’t imagine the lifestyle.
7,118
@bearbait was right from the get-go. The pin could be pulled from the other plug.
Many thanks my friend.
Many thanks to Wolfman for clarifying it.
Just couldn’t take it to California….😉
5,161
This is the latest NEMA (National Electrical Manufacturers Association) picture of the various plug and receptacle types. Knowing the proper code identification will help you to get the correct item every time.
Flintknapper
L2350DT
May 3, 2022
2,007
2,550
Deep East Texas
Oh believe me....I know.
My Daughter is an 'RN' and has been 'Travel Nursing' for the last 12 yrs.
Currently out in Commiefornia (the last 3 years). Says it was Culture Shock at first for a Texas Girl.
3,705
It’s Californica that causes Cancer.
I used to have to go there for my work…but the only part of that place I ever enjoyed was the Northern portion of the state…specifically Mammoth/June Lakes.
7,118
She’s been out in the Monterey Bay Area for 9 years.
Loves it.
She and her significant other pay more in rent than mom and I made (gross) in our early years….😳 Just can’t imagine…
That said, he’s got a boat and a slip for fishing in the bay and the Pacific. They like it there.
7,118
While I’m probably not going to use it, principle dictated I complete the fashion of a pin for the CS6364 plug.
I don’t have the machinery some our OTT friends have. They’re so gifted, and I appreciate them sharing here.
Bench grinder and an impromptu “lathe” got it pretty close to the pin I was trying to replicate.
Q
Just need to cut to length… if I were to use it.
jaxs
B1750HST
Jun 22, 2023
1,001
773
While I’m not going to use it, principle dictated I complete the fashion of a pin for the CS6364 plug.
Q
