L3400 issue
Mijpa
L3400
Feb 18, 2024
9
Arizona
Tried using travtor today dash lights up but when turn key fully I get nothing like totally dead.
battery seems good 12.4v about same at starter switches ohmed good any idea??
2,831
Battery is NOT good at 12.4 ..........
check ALL your cables - Especially the ground.
You have a battery to jump with by chance?
8,743
Check the PTO and if it's an HST check the position of the treadle pedal.
8,743
Do you have the WSM (aka Service manual) ?
It has all of the troubleshooting info in it.
Mijpa
L3400
Feb 18, 2024
9
Arizona
Hold the key in the Start Position, and move the HST pedal back and forth slowly. Wiggle your butt in the seat, more your weight around. Then play with the PTO switch, force it further backwards with the key in the Start position...
Yep I tried that last night
Mijpa
L3400
Feb 18, 2024
9
Arizona
Ok I finally found problem. I jump starter and it spun so I moved back to neutral safety switch. It is making contact with plunger just not enough , I put a small rock in between plunger and bracket that makes contact fires right up.
so how do I fix something that already has pre drilled holes for safety switch I can’t move it up or down?
