Early BX2200 with LA211 FEL - loader hoses messed up
kubotasam
Apr 26, 2010
1,208
131
Alfred Maine
[QUOTE="TheOldHokie, post: 518135, member: 46622"
The only position that is using cylinder regeneration is position 3 which is "fast dump". When you go past that to position 4 you have normal speed cylinder/motor control. With the 3 position valve your only have regenerative dump which will not work with a motor.
[/QUOTE]
I made my 3 position regeration only valve work. See post 34 above.
5,099
[/QUOTE]
I read it. Interesting workaround.
Dustyx2
BX22, M7060, Landpride RC-2512, Woodmax SB84
Feb 19, 2021
225
67
NE Wyoming
Four position is both which is why it is preferable. My understanding from discussions on this forum is the Kubota four position valves function as follows:
Position 1 - neutral tandem center - both work ports blocked and pump unloaded to HPCO
Position 2 - Pump to cylinder, cylinder to tank
Position 3 - pump to cylinder, with cylinder regenerative loop
Position 4 - pump to cylinder, cylinder to tank.
Thanks for clearing that up for me.
Mikebx2200
BX2200, LA211, BX2750D
Jan 8, 2022
Pennsylvania
You could replace it with a 4 position valve that gives you regen and motor control. There are multiple aftermarket valves that would work but they arexa little pricey. I would simply add an inexpensive ($75) single spool valve next to your existing valve and use it for the motor control.
I'll probably do that. Do you know if the existing Kubota 3 way valve with regen on my BX2200 has an open or closed center valve? If I price a new valve I need to what kind of set up I currently have.
5,099
Your tractor is open center. and your auxiliary valve should be open center with power beyond. Here is one I mounted next to the LA525 loader valve. It's my quick and dirty third function for a grapple.
5,099
You'll want about the smallest GPM valve offered too.
The valve in my picture is an 8 GPM Prince Wolverine MB11B5C11. Compact, readily available, comes with the power beyond adapter, and costs $115. The ubiquitous 40 LPM P40 valves sold by Summit and a host of others are also good fits and a bit cheaper. The power beyond sleeve is usually not included and will add $20 to the price. The very low cost ones also often have BSPP not SAE ports. In the US the BSPP port adapters are less common than SAE adapters and a little more expensive so they also eat up your "savings".
