Connection issues 9/23
Fordtech86
L3200
Aug 7, 2018
4,708
5,481
Pineville,LA
@Mr. K
Anybody else experiencing connection issues to OTT today? I keep getting
throughout the day. Will last about 10-20 minutes usually. Have had no issues with any other site. Also still keep getting the constant refreshing when viewing or replying to threads. I only use my iPhone so not sure if PC users are experiencing the same issues.
2,105
I think there was an outage there for a bit ......... I refreshed my idle screen around lunch time and got a server issue problem - that was fixed quickly
Fordtech86
L3200
Aug 7, 2018
4,708
5,481
Pineville,LA
Thanks hokie. This has been happening off and on all day for me. This was the 5-6 time when I made this post after getting back in. The constant refreshing has been happening for 2 months or so.
4,003
@Mr. K
Yup....
Had that problem earlier this PM.
L4701, T2290, WC68, grapple, BB1572 box scrape, Howes 500, 16kW IMD gen, WG24
3,510
@Mr. K
Like you, I only use my iPhone and the frequency of refresh made the site virtually unreadable; definitely no way to post as it was more frequent trying to post and I’d lose part or all of whatever I’d typed. Had to move away from Safari to Brave as a browser. I still use Safari for everything else with no problem. No OTT problems with Brave.
977
This site is nearly useless for apple products using safari browser.
No idea why this site should be any different than the others but it is the only forum I frequent but I don’t know how much longer I will be able to tolerate the problems (refreshes, won’t type in the reply' , locks up'
BX23S
3,695
Add the hijacked links that direct you to an advertiser's website. I wonder if the administration is keeping up with the Xenforo updates? XenForo 2.2.7 is now available.
BAP
Dec 31, 2012
2,514
658
Sure it’s not on your end? I use IMac and IPhone with Safari and don’t have any problems.
3,510
I have same problems as Russell King with iPhone 8 and Safari. Switched to a different browser (Brave) at the suggestion of I forget who on this site and all the problems with refresh and misdirects went away. I still use Safari for everything else. This is still the only site I’ve ever had a problem with. Works fine on Brave. Tried on Safari again right before this response. Still unusable on Safari.
I don’t know the tech side of it at all. If it’s on the user end, there are multiple users with the same problem, which could be the case.
3,877
Like BAP - - no iPhone issues with OTT here either. I'm no tech guy.
Interesting you guys have several.
I'm usually on my home wifi, not sure if that has any bearing.
