Engine Stop Solenoid bx23s
95Mustang
32
Franklin new Hampshire usa
I need a new stop solenoid ....
Kubota part # 1J025-60010
Is there anything out there that works .
The kubota part is 130 bucks ouch
I've seen ones on amazon for b series tractors for
40 bucks
Any leads ....????
9,169
40 bucks
Any leads ....????
A kubota is reliable and hardworking because of the parts that it's been built with.
Start throwing a bunch of junk, off name, cheap, parts into it and you'll end up with a cheap unreliable tractor. :rolleyes:
Did you buy a kubota to try and turn it into a off name chinese knock off, I would bet not. ;)
95Mustang
32
let's see ....brand new tractor with less than 175 hours on it
Complete driveshaft failure at 11 hours
Blown head gasket and bad water pump at 80 hours .
And the solenoid failure at 170 hours .
Yeah they're built with quality components for sure ....
Bwahahaha
9,169
Bwahahaha
Wow your hard on machinery. ;)
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
I've always had a few customers who seemed like they could break a crowbar in a sandbox. I never could understand it either because it never looked like they were the type to be rough on equipment! I guess they were just unlucky and happened to buy the lemon. We sold hundreds of BX tractors since their introduction and very few of them do we ever see again. A lot of them get bare minimum maintenance too and still keep on keeping on. But there always seems to be that one!
5,501
2,208
Yeah and most of "those" that I've seen are using BX's for D9's. Yeah it's a litlte bitty tractor, aka big lawn mower that a backhoe and loader will fit, and it'll do a lot of work for it's size but I think some take that too far. It DOES have limitations. Yes I know of a few of those same "type" people.
95Mustang
32
Keep drinking that orange kool- aid .......
Bwahahaha
6,886
95Mustang, if you're so offended by the comments why do you keep coming back. You apparently have a machine that has failed you, no matter how it was used/treated, and your disgust can be understood.
You're probably not familiar with any other mechanical apparatus that has performed poorly or failed from it's design. It happens everywhere, and frequently.
Your comment, "Keep drinking that orange kool- aid ..." could be changed to any color on the color wheel. All manufacturers face those challenges.
Your solution is with your dealer, might go bark at him! Maybe you'll have to purchase a different color tractor to really be happy, but beware these thing happen everywhere!
95Mustang
32
The 29 dollar solenoid from ebay works perfect.
Plug and play , no drama .
It would have cost a lot more than 29 bucks just to get the tractor back to the dealer from where it broke down .
So for those that tried to offer help ...
Appreciate it.
To the rest of you helpful fellows ......
Well let's just say Mama taught me if you cant say something nice
Remain silent ....
Bwahaha
6,886
95Mustang, good you came to an inexpensive solution.
Go back through your thread and see if you followed your mama's teachings, specifically post #5 and #10. Seems you're a little overly sensitive to comments made by those with years of experience with the product you complain about.
Your final comment indicates you think some of the post here were not intended to help. You must be use to some other forum's technique!
5,777
Hmm.. blown head gasket may be due to loss of coolant. There was a recall on mine( last year) to replace the overflow tank cap. Plugged hole allowed coolant to NOT goto into tank..poof, into the air.
Heat gauge 'should' have alerted you to overheating.
re: starter solenoid. Be sure the 'control' wire is secured onto the tab. Mine 'fell off' after 30-40 hrs.. I used tiewrap...238hrs on without problems.
Jay
