4wd clunk
summit1966
L2850
Sep 26, 2017
14
Australia, VIC Melbourne
Hi all,
I have a 4wd l2850 shuttle shift tractor with FEL. The last time using it i noticed when in 4wd there is a serious knocking directly under the seat, doesn't do it when going straight more when turning or clutching out. Runs fine in 2wd no noises at all. What could it be?
8,743
Most common and simple issue is worn joints on the Propeller shaft, pull the shields and inspect. ;)
6,623
Look at the splines under item #20. Take the shields off. Remove the roll pin, slide the coupling, notice the condition of the splines on the shaft and and the splines in the coupling.
torch
Jun 10, 2016
2,733
955
Muskoka, Ont.
What kind of terrain? 4wd requires some wheel slip when turning or it will bind up.
8,743
The couplings get worn more than the shaft and will slip if worn too much. ;)
