Model: B-2150.
So I turn the key on, get two red lights. Turn it to glow-plug ... get the glow plug light, the other two dim. Turn it to start ... the lights go out and nothing happens. Not even a click or a bit of a crank.
I had the starter bench-tested, it works just fine. I've got current at the starter bolt where the starter wire is bolted on, it's slightly less than the battery (and there's a current even when the key's turned off, I don't know if that's normal). I'm pretty sure it's not shorting, I don't see any sparks when I turn the key, and I tested the starter body, it doesn't have any current.
The battery reads 12.2v, which might be a little low, but even then I should get at least a click from the starter or a slow crank from the engine.
Suggestions? Is it possible the ignition switch isn't working? It feels like it's something between the battery & starter, and I think that's all there is, unless there's a fuse I don't know about that's blown.
