Fuel can spouts. I'm tired of breaking them
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
321
27
23
Mobile, AL
I know the reason I'm breaking them is because I lean the spout on the tank. Has anyone found a solution to this problem?
Untitled by bambam32, on Flickr
sburn518
L3800DT, la524 loader, bushhog,box blade
May 13, 2014
10
Goode, Virgina
I use a hand siphon hose that came with an old kerosene heater to fill my 3800 out of a 5 gallon can. Set the can on the seat or the hood fill it from there. No more mess all over the hood or trying to hold the 5 gallons of fuel up to fill the tractor.
bcp
BX2360
Apr 20, 2011
644
79
SW WA
I've never cracked one by leaning it on the spout, but I have done it exactly like that by over-tightening the clamping nut.
Bruce
Swampcollie
Mx5800, la1065 loader, rcf2772 mower, blade, disc
Aug 19, 2016
Sedalia, mot
Im an old guy. I got a mr funnel and no longer use the spout. Just pour it in. Much quicker, cleaner, and filters the fuel.
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
Jim L.
869
171
"No-spill" yellow 5 gal container with handles top and back.
It will sit on top of the L3800 and works like a charm.
billrigsby
Mar 17, 2015
1,039
217
Florissant CO USA 8213'
www.facebook.com
Kingcreek
Grand L3010 GST 4wd, LA481FEL, various attachments and accessories
Aug 3, 2011
457
NW Illinois
I hate those new spouts. I throw them away and use a funnel.
Yooper
3901 LA525
May 31, 2015
1,659
804
NE Wisconsin
I have the same fuel container that Sheepfarmer referenced, and I really like it except for holding down the button while filling the tractor. I solved this issue by installing a cam to hold down the button. Now I set it on top of the hood, flip the cam and just keep and eye on it until empty.
evanyj350
'07 BX24
Apr 11, 2012
9
Amherst, MA
Love my VP racing high flow cans. I even drilled the top off one and tapped in the next bigger size hose barb.
Also use a shake siphon on some pcs of equipment. Set the can down at a level higher than the fill hole, shake the siphon and watch it drain.... a little slower, but you don't have to hold the can.....
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
Yooper where did you get the cam? Can it be adjusted so flow not too fast?
