Press Brake
DThrash
7030SU MX 4700
Sep 29, 2015
184
Eutaw AL
Got another new toy today and man does it beat a hammer and vise. Press brake fits right on a HF 20 ton press. $219 off ebay. They say it will bend up to 1/2" thick 3" wide piece. Not planning on pushing it that far.
Tooljunkie
May 13, 2014
4,150
I like. Looks easy to build. I have all the pieces. Have had a need but vise and hammer is therapeutic as well.
Probably cheaper to buy then build.
hodge
Nov 19, 2010
2,958
528
Love, VA
I built my own, and use it every day. If you have a shop press, a brake is an awesome tool. I have about $10 in mine.
4,365
Thats pretty cool,, I have no idea what I would do with it cause I cant weld it to anything anyway,,, still pretty cool none the less
DThrash
7030SU MX 4700
Sep 29, 2015
184
Eutaw AL
Still have not bit the bullet for a band saw. I always thought it would be good to have more orders than you can fill for a device. I'm in that situation and it is stressful.
hodge
Nov 19, 2010
2,958
528
Love, VA
I have a band saw, which I do use. But, I use a porta-band much more often, and I can make 5 or 6 cuts in the time that it takes the band saw to make one.
4,365
So what pray tell are you building?
5,504
2,213
what kind of press is that? I am in the market for a press since my old one was given away without my consent. Old one came from a chinese tools store, looks like the one in your picture. All the new stuff I've found are all about identical to the HF 20t press, and all that I've seen are garbage. I don't mind paying a little and I realize I'm gonna have to pay, but ain't no way I'm paying hard earned money for a piece of junk that I get 2 uses out of before it's broken or bent.
Tooljunkie
May 13, 2014
4,150
I dont use mine daily, but i do use it often. It was a cheap one i bought almost twenty years ago. Could use a bigger one sometimes. Bressing bearings, bending sheet metal,die forming.borrowed a feather and wedge kit and cut a keyway in a hub once. Brass hammer is much faster. Pressing ball joints on certain vehicles.
I think a press is a necessary shop tool, just under utilized.
8,680
I bought mine used/local- it was like new, and came with a 16 ton pipe bender (brand new), for $400. From the best that I can tell, this is it-
http://www.carolinaequipment.com/04_Presses/20Tpress/20Tpress.htm
I bought an air over hydraulic jack for it, and use it every day. I've gotten my money's worth a long time ago.
That air over hydraulic is nice :D:D We have a 30 ton press at work that's air over hydraulic. It replaced a 20 ton with the two spring loaded bars that acted as stabilizers for a carriage. I bent the stabilizer bars and shot the shaft I was stripping into the wall. :eek: dented the snot out of the metal siding. Glad it shot away from me instead of at me, or else I would have likely ended up in the hospital :eek:
New one has a solid mount with a long travel piston instead. Much sturdier, and safer to use :D
Yooper
3901 LA525
May 31, 2015
1,668
817
NE Wisconsin
Your thinking is right on. The general rule is the bottom die width should be eight times the thickness of the metal up to 1/2", and ten times for thicker than that. For 1/2" thick, that would be a 4" die. You can cheat it a bit, but your tonnage will go up with a smaller die.
DThrash
7030SU MX 4700
Sep 29, 2015
184
Eutaw AL
A fish scent/ attractant applicator, mounts to trolling motor or seat pole, soak the foam pads in fish attractant and you can pull just about any soft plastics through it. Jig and spinner baits will come through if careful. Foam is attached to plastic sleeves that slide on the alum. flat bar. I use the press to put that small bend in the flat bar so the foam stays in place. Soak it once or twice a day and will not not have to be looking around the boat for the spray. Saves time and money. My wife and used a similar device last summer, we fished 16 tournaments and got paid in 13 of them. Don't tell me smell doesn't make a difference.
4,365
What do you do with it? I get the scent thing but I cant figure how your using it, drawing the lure and line through it?
Hummm wait, I think i got it,,never mind
DThrash
7030SU MX 4700
Sep 29, 2015
184
Eutaw AL
I knew you would get it, the foam puts a nice coat of oil on the bait. Saves a lot of time and scent. Took me awhile to find the right foam and the right tape that the oil would not break down.
