No matter how I adjust this plow it wont cut out, over, to the row that I just plowed before. Forgive me for not using the correct terminology but it leaves a gap between rows. Ive plowed before several years ago and remember correcting this problem but dont remember exactly how. Besides it was a different tractor and different plow.
I have the adjustment bar all the way over as you should be able to see in the pictures. After making some adjustments on the tractors right lift arm and top link then it started plowing pretty darn good except the problem Im having. I took pictures of the worst plowing so you could see some of the bad gaps. I have Hodges stabilizers on so I do think that helps.
Im also staying to the far right side of the furrow to cut over to the last cut as much as I can. Yes I didnt think to take pictures with the plow attached. So let me know if there are any other pictures you need or questions. Thanks
Warped plow ? It looks pretty straight.
Maybe its more out of wack than I think.
Help
Help
