M5700 Engine Cylinder Wall Damage
vette31061
M5700
Apr 26, 2010
Gordon, GA 31031
The dealer service informed me today that my M5700 has sustained cylinder wall damage that will require a long block replacement engine, The damage they think was caused by an either explosion, which to my knowledge has never been used in the engine. Tractor has been used about 250 hours since purchased used (226 hours) in 2005.
Any other explanation for damaged to a localized area ?
not a groove all the way around the cylinder and there is some light vertical scoring.
Are there any other options to repairing cylinder wall damage to a non-sleeved engine?
Is a short block available?
Are rebuilt engines available? If so from who? no luck so far on internet search.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
Sorry to hear about the bad luck. That sure is a small amount of hours to go thru that type of damage. Did it drop a valve or are they still intact? Exactly how bad is the damage and what did it look like?
vette31061
M5700
Apr 26, 2010
Gordon, GA 31031
Damage is located near top of cylinder wall and is several thousandths deep, about 1/2 -3/4 inches long. very rough feeling, There is no ring around the cylinder. No dropped valve.
Service tech says that it is explosion damage, normally caused by using starting fluid. No starting fluid has been used in this engine since I have had the tractor.
Took it to the dealer for gray ehaust smoke and oil blow by on side of engine.
Blow by was caused by a damaged PCV hose.
Gray exhaust started last last summer. Have noticed a slight loss of power.
Is there a source of remanfactured Kubota diesel engines?
If I have them just put the back engine together and I run it, what is likely to happen?
Bulldog
Mar 30, 2010
5,434
78
Rocky Face, Georgia
If they have already told you the only choice is a long block I think I would put new rings on that one piston if it was good and run it. Sounds like it was still running pretty good when you brought it in. To me if the dealer is saying long block they are telling you the entire engine is going to be replaced. You no how it was running before. Do you think it was running bad enough to need a new engine.
aquaforce
L245DT FEL, JD450 Track loader, 5' scrape blade&mower, 5x10 trailer, Dump truck
Apr 22, 2009
757
Stockbridge, Ga. USA
I HATE EITHER ! ! !!!!!!!!!!!
:mad: :mad: :mad: :mad: :mad: :mad: :mad:
I really think that stuff is for incompetant fools. If an engine won't start there are reasons and the best simple way to start the engine up is to address the condition effectively. Did I mention that I hate either?
traildust
B7610HST 4WD, LA352 FEL, Gearmore 2 Spool Top & Tilt Box Scraper
Jan 27, 2010
1,490
Phelan, California
I thought you hate big tractors :confused:
traildust
Jan 27, 2010
1,490
Phelan, California
Vette,
It sounds like you got the raw end of the deal from the previous owner. I bet they squirted the laughing gass in there and didn't blow the engine but did stress and fatigue it. Unfortuneatly through your normal use the damage quickly progressed :(
This is a very sad thing and I wish you good luck!
RDR
M5400,B6100E,K008,L175,TG1860Diesel,JD355D,3)Leyland 154D's,YM2000,IH1466
Oct 13, 2009
147
Danevang, Tx.
If it doesn't have sleeves it should be able to be bored oversize. I don't know why they haven't told you this.
I've never heard of ether putting a scratch in a cylinder unless it broke a ring on the piston. If it is a narrow scratch I would put rings in it and run it. I have a B6100 that is so worn out you can't stand down wind of it because of the blowby. It starts, runs and does anything I want it to do. It doesn't have any gray smoke in the exhaust.
