wrong tire and rims
chris989
L3450
Oct 5, 2016
37
boise
Hello,
I have a L3450. I am in need of new rear tires. I always knew something was a miss because in 4wd i had drag.
OEM calls for 12.4-24s (45"dia) I have 17.5-24s (49"dia)
I was going to buy the 12.4s but they call for a much narrower rim. My 17.5s are on a 15 inch wide rim.
any ideas for a non $$$$ option would be great. My thought is putting a tube in the rear and increasing the size of the fronts a little if i can figure out the math. My guess is the front tires are cheaper than new rear tires and rims.
Thanks,
Chris
BAP
Dec 31, 2012
3,175
1,293
What size are your front tires?
7,648
Interesting, I have an L3250 that has 13.6 x 24's on the rear and I think 7.3 x 16 on the front. Factory, I'm sure.
11,041
Yes much cheaper to mess with the fronts, Like said, what size fronts are on it now?
chris989
L3450
Oct 5, 2016
37
boise
the fronts are Denman skid steer plus 10-16.6 (30.4" dia). when i look at the part list, there ar a handull of tires listed for the front. the 10-16.5 are one of them so i guess it is right?
chris989
L3450
Oct 5, 2016
37
boise
My horrible math calculates i need a 33" dia tire for the front.
12.4-24 = 45"
45"x 3.14 = 141 circumference.
141 divided by the correct 10-16.5 (30.4") = a ratio of 4.6480"
If i take my incorrect 17.5-24s
17.5-24 = 49 dia
49 x 3.14 = 153
153 / 4.6480 ratio = 33"
Does this math seem right?
only proble with this approach is it might require a bigger rim?
