what fluid (newbie)
dumbie
SAINT JOHNS mi usa
Well here it does I have a l2900dtgst I'm doing some work on the tractor and had takin the oil pan off in doing that I had lots a fluid came out where the 4x4 shaft hooks in well found out why that happened so I fixed that part but what kind of fluid is it
gpreuss
Oct 9, 2011
1,166
Spokane, WA
It should take 42 qts of Kubota Super UDT fluid. You get it from your Kubota dealer. Expensive.
2,170
Thats what I'm afraid of can I use tsc trans/hydraulic fluid
Thanks dumbie
You could use extra virgin olive oil ;)! But that too is expensive and would gum up the works! The S UDT is gonna be expensive too, but how MUCH more that TSC ? TSC is about $40 a 5 gal, you need 10 gallons....
the Kubota 70000-40205 Oil, 5 Gal Super Udt2 is about $115 for 5, $230 for ten......or so.....
bottom line - $150 bucks is cheap in the long run of things! I am with Skeets, do a nut check - buy the stuff and dont spill a @#$%@## drop! :D
5,121
Thanks dumbie
NO! GST's are very picky about the type of oil you use, too heavy like the TSC oil and it will not shift right and will give you problems and possibly cause damage to components!
littleorange32
ZD 21 Pro M105X BX 2660-(for sale!!)
May 9, 2014
brooklyn
hey everyone, new to this. I need some help. I have a zd21, i checked fluids and didnt put this on correctly. now there is fluid on floor of my barn. Im not sure what fluid to put back in. Is this the rear axle gear? Final drive housing? I dont have the operators Manuel for this. I would like to replace the fluid that came out over night so no problems arise. Thank you!
