Weekend buy
Bowhunterick
White Cloud, Mi, USA
Over the weekend I bought a 2000 B2400 HST that looked to be well cared for.... yesterday I hooked up my brushhog and tried to lift and nothing happens, I look down and I can see hydraulic fluid gushing out of the line. When I investigated I found a spliced piece of rubber hose on the metal hydraulic line. When I asked the previous owner how long that line had been spliced he acted like he didn't know about it. Replacing the line looks fairly straight forward - a 1" bolt at the position control valve, 2 smaller bolts at the hydraulic block type outlet and another nut at the flow priority valve. I can hardly get my wrench on the last nut because there's a another line beside it and in the way, am I OK to remove that line too? Sorry for the lengthy post.
2,831
I wonder if there is another way to fix that, other than the half/ars hose patch. Are the lines screwed in at the block or attached to the block as one unit?
6,633
I think the hose is there for some flex in the system.
I'd take a box blade and cut the bad hose off. There should be a gap between the two steel lines. Get the new hose and take your knife to chamfer the inside edges and put a little oil on the (inside of) hose to make it slide on easier. Slide it on and pull it back the other direction and clamp.
I'd try this before removing the ends of the pipes.
Post some pictures so we get a visual of your situation.
8,756
This is what your dealing with, nope no rubber hose in that line, it does have a rubber sleeve that fits over it for a clamp to ride on (#190).
Have your Serial# when you go to order a new line as there are 4 different #'s. also get 2 new crush washers #'s 160.
Central Joe
B7100 Grading Blade Disc Roto Tiller Scarifer Rake 48" Finish Mower
Mar 26, 2015
40
South Carolina
How about a compression fitting? I have repaired lines with them, but not sure about pres. you are working with. I would try it. joe
Tooljunkie
May 13, 2014
4,150
There are compression fittings for hydraulics. Areoquip or Swage-Lok are the common manufacturers.
Will also require a hydraulic hose made up. In this situation where there is little room for error, a new pipe would be money and time better spent.
