Water in Hydraulic Fluid
jsmoor
Kubota B2650
Nov 1, 2019
Ellensburg, WA
Somehow the rear oil cap situated at the back of the tractor (B2650 HST) between the two lift arms came out. It's stored under cover and I don't think its been missing for long, otherwise I would have noticed. I did however get some water in there when I was spraying it off before doing some routine maintenance. Not a lot but enough to cause concern. So my question is what to do?
My thoughts are:
1. Leave it open in hopes that it evaporates.
2. Over fill with hydraulic fluid and hope the water gets pushed out
3. Change the fluid - don't know if this is necessary and could potentially
expose more parts to water.
4. Something else I'm not thinking of
Thoughts?
9,297
Your ONLY option is to drain it completely without moving it!
If you do move it you can do damage to the HST, they do not like water!
Also change the filters!
5,801
re: #1....
Oil floats on water ! One of them 'physics things'.... so it'll NEVER evaporate. Given enough time, it WILL settle to the lowest point of the HST that it can get to, providing you do NOT run the engine.
The ONLY option is to drain the HST and replace filter. If possible ,allow HST to drain for 1-2-3 days, at the very minimum a long overnight session. The more it drains, the more watery-oil will come out.
When I rebuilt a 'drained' JD HST, 2 days later it was still dripping into the bucket ! Oil don't come out fast.....
3,654
My thoughts are:
Thoughts?
DON’T RUN IT!
HOW do you KNOW?
How do you know you got water in it? If you RAN the engine with water in the hydraulics then the water will be mixed-in with the hyd-fluid and will likely turn “milky”. That would be bad and will be difficult to clean out without multiple hyd-oil changes.
IF you got water in it, then the water should settle to the bottom of the oil. But predicting how much and where it settled is not something easily determined. Presumeably the drain plugs are the lowest point. If it were mine, I think I’d drain a gallon or two out after a few days of sitting still....and see if I can find any water in it.
If I DID find water I’d do a complete changeout of the system. If not then I’d run it awhile and then check to see if there’s any indication of water having mixed into it.
Full Disclosure: I’ve never actually done this in a tractor, but I have experienced it when another vehicle was submerged in a stream-crossing. The hydraulic system fluid (a red H5606 hydraulic oil similar to transmission fluid) became very “pink” or “milky” . This was many miles deep into a forest and we had no choice but to continue operating until returning to civilization, where we deliberately overfilled/overflowed the system by pouring several gallons of new hyd-fluid into the fill-neck while the engine and pump was running, until the milky appearance returned to solid red. It was not the best way to do it, but it worked and had no issues for more years of operations. (This was back in the early ‘60s and EPA had not yet been created.)
bearbait
Dec 9, 2011
4,133
891
New Glasgow Canada
What NIW said. Also when you drain it leave the drain pug out over night along with leaving the filters off. In my experience with putting a mid pto in my 3560 it takes a long time to drain completely.
Tire Biter
B 2601 434 loader MMM, bunch of tractor stuff . Ford 4600
Jul 10, 2012
236
88
S.E. TN
Drain the oil out (all of it) and plug the fill port and trans. vent and pull a vacuum on it with a vacuum pump. Back when I used to work, I serviced commercial refrigeration equipment and occasionally I’d work on water chillers that burst the HX tubes and flood the refrigeration system with water. Hours under a vacuum and several oil changes and the system would be moisture free and returned to service. Water will boil at room temp when in a 30” vacuum.
9,297
OH NO! Doing that would destroy every seal in the transmission, internally and externally.
I get where your thinking was going, but it simply won't work on these. ;)
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,268
174
Coyote Flats,Texas
I agree the only thing that will cause water to evaporate is heat of operation plus an open breather hole for water vapors to exit. BUT operation of hydro trans with water contaminated oil is not a good option.
Water weighs 8.3#s per gallon while oil weighs 7.2 #s per gallon so if oil doesn't have additive to absorb water the water will settle below the oil.
I agree best method to remove water from reservoir is drain & install new oil
Mlarv
BX23S
Jan 19, 2020
227
179
Crossville TN
Maybe try this
before anybody yells at me I am guessing and asking if this would work. Could you drain it then run some alcohol though it to absorb the water, then let it dry and refill? By run it I mean put the drain plug in fill it then drain it again. Or will the alcohol be better to drink while you watch it drain the oil and water?
Mike
Fluke631
B2650
Oct 29, 2019
70
No alcool needed, I have seen many hydraulic contamination in the helicopter world. The only way was stated above. Drain and refill
If you ran it already it's a bit more complicated. You need to flush out all the systems, cylinders etc.
I also suggest a full flush. Drain refill, overfill, drain again. Don't forget to let it sit once you refilled it so you can see when you pull the drain plug if you have water.
Water is always at the lowest point after a good settle.
boz1989
B2910 fel 60 mmm, Land Pride rb1572
Jun 10, 2015
269
Portland, MI
I would recommend drinking the alcohol, your tractor seals might not like it as much as you, but I don't know this as a fact.
Sent from my LGMP260 using Tapatalk
9,297
Re: Maybe try this
Mike
Yea drink it, or use it to decontaminate everything within your reach, but keep it out of the hydraulic sump, no good could come of that! :D
3,654
Alcohol is BAD for rubber seals and gaskets. That is one reason to NOT USE transmission or power-steering “leak stop” or such snake oils...they contain alcohol.
Alcohol will SWELL seals and gaskets ...and TEMPORARILY might reduce or stop leaks. But when the softened seals return after that alcohol evaporates... they will leak all over again...usually worse!
And alcohol used to attract water in the transmission... will also eventually evaporate...and leave that water right back where it found it. And your seals/gaskets will be damaged.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Assuming you haven't cranked it a single drain of fluid will fix your problem. If you have cranked it the entire system is contaminated and will require multiple drain and refills to flush the system.
That cheap plastic cap may cost you a $1000 before you get it clean.
Tire Biter
Jul 10, 2012
236
88
S.E. TN
Ok don’t do that:D
How about just opening every port and heating up the case? Drain all the oil first aim some infrared heaters at it and evaporate the water?
JerryMT
Kubota M4500, NH TD95D,Ford 4610
Jun 17, 2017
529
153
The Palouse - North Idaho
My thoughts are:
Thoughts?
If you haven't started the tractor, the water will collect at the bottom of the sump, Drain a quart or two out and then wait a day and drain another. Check for water. (Drain it into a glass jar so you can see the oil/water interface.). Do that until what you drain has no more water, or until you run out of fluid in the machine.
3,654
Ok don’t do that:D
I hope you have a lot of spare time. (It might take a lot longer than a virus quarantine to accomplish the desired results...especially if the water has already mixed with the oil.)
If it were mine, I think I’d put some cheap hyd fluid in it, run it to thoroughly mix it all up and then drain it again. And again, if necessary. But after the majority of the water is gone, it should be fine to operate until the rest dissipates.
Back to an earlier question: How do you KNOW your power washing the tractor injected water? Have you attempted a sampling of the hyd fluid?
jsmoor
Kubota B2650
Nov 1, 2019
Ellensburg, WA
Thanks everyone! I changed the fluid and filters after letting it drain for a couple of days. I think I dodged a bullet. I saw no evidence of water so I must have lucked out. I really appreciate everyone's input.
bearbait
Dec 9, 2011
4,133
891
New Glasgow Canada
Awesome, thanks for letting us know.
