My first tractor: B7200. The breather tube that comes off the top of the valve cover exhausts oily and drips on oil filter. Is the problem worn valves or is this normal
Some "blow by" is normal. An excess amount is usually worn piston rings.My first tractor: B7200. The breather tube that comes off the top of the valve cover exhausts oily and drips on oil filter. Is the problem worn valves or is this normal
Blowby is normal on these, but it sounds like you might need to take off the valve cover and clean the cover and the vent baffle in the cover.My first tractor: B7200. The breather tube that comes off the top of the valve cover exhausts oily and drips on oil filter. Is the problem worn valves or is this normal
Horsethit!.
Also consider changing the motor-oil you use. Some brands of oil are KNOWN to 'outgass' more than others. (MOBIL1 is one of those)
MMO=Marvel Mystery OilMMM=Marvel Mystery Oil
Never heard of engine oil "outgassing", in fact a Google search doesn't return any references to that assertion.Also consider changing the motor-oil you use. Some brands of oil are KNOWN to 'outgass' more than others. (MOBIL1 is one of those)
Good question! The term 'outgassing' was my own... I believe the more technical interpretation is when light hydrocarbons tend to vaporize out of a motor-oil. There is ABSOLUTELY a difference among motor-oils in this regard.Never heard of engine oil "outgassing", in fact a Google search doesn't return any references to that assertion.
Care to cite your source for that "KNOWN" fact?
Just curious.
