Using a gas can that previously had unleaded
zake1000
L2800
Jun 18, 2014
20
Athol, MA
Hi,
I feel a bit dumb asking this question. I've been looking online for a while and can't get an answer.
I have 5 gas cans that I purchased when we had a really bad ice storm (for the generator), and lost power for 6 days. The one that I use currently is marked very clearly, so I can't confuse it, but the pouring spout makes it difficult to pour. With the newer cans that had unleaded in them (been empty for about 5 months now), I am able to tip it upside down easily and release the gas only when I press the adapter on the spout in with the side of the lip of the gas tank (where the lid screws in). this makes it a lot easier and prevents spilling gas over the hood.
Is it ok to repurpose (from now on) one of the gas cans that previously had unleaded in it to now carry Diesel? I don't care about the whole red vs yellow debate that I've seen on other forums. I haven't had any issue filling my current diesel gas can (red) at any of the local pumps, and have seen a lot of other people doing that as well.
thank you.
2,173
Hi,
thank you.
Not sure there is a law, hell in this country there will be soon!:eek: But as long as the can is "clean" on the inside and the diesel filler nozzle will go in it , fill her up.
Here is something you can do, take a couple of pieces of duct tape, place on a hard surface like glass, overlay the word diesel from a computer printer, cut the tape out, carefully place tape on "red" container and paint throw it in yellow......
the can is the can - only you know what is in it.........
5,135
Like he said a can is a can, just make sure there is Zero Gasoline in it... check with a burning match... oh wait strike that! :eek:;):D
Just get a can of Yellow plastic paint and give it a paint job just so you don't ever mix them up.
4,395
At a hardware store you should be able to find a marker used for marking structural steel. It's like a tube of toothpaste with a small BB in the end that rolls when you put pressure on it. (Once you have a tube you'll use it for things you never dreamed of)
You can print DIESEL or 50/50 or anything else you need the can for and the writing stays on the container. If you mix diesel and gas beyond about 15% gas your injectors might get TOO clean.
Burt
Mar 24, 2012
337
Goldendale, WA USA
Hi,
thank you.
Zake1000,
We have a "red" can, 2 gl I use to top off diesel with. To identify it, I used one of those wide permanent markets and wrote "Diesel only," on the top and sides. It stayed on the can. That way, if someone else picks up the can, they know it's purpose. I also have a larger yellow can but I find that topping the tractor with the smaller can is easier and tends not to spill.
Burt
zake1000
L2800
Jun 18, 2014
20
Athol, MA
Thank you for the replies, but labeling the container is not what I'm worried about. Can I use a container that previously had unleaded gas in it, that has been empty for a few months, to put diesel in it.
Will having previously unleaded in it cause any problems to the tractor?
TripleR
Sep 16, 2011
1,911
SE Missouri
I "think" everyone is saying you can and I agree, we've done it and we have also put gas in diesel tanks and diesel in gas tanks, cleaned them out and used them. One of our 300 gallon fuel tanks use to hold gasoline.
While I prefer to use yellow for diesel and red for gas, this has not kept my wife from putting diesel in our ATV or gas in a lawn mower...
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
In answer, sure use it, but waste a little diesel fuel first to rinse out the insides. I use old engine oil cans and do the rinse first. Never had trouble with any.
flynavy
B7100 HST-D w/FEL,654 Whel Hrs w/blade, 2654 Hsqv mowr, 28h Cfstm snowblower&cab
May 1, 2014
95
Laurel Springs, NJ
Everything I'm reading with regard to replies is good advise. Especially like the decal reply, time consuming but good none the less, or even spray painting the container idea good advise + easier. The stores also sell DUCK brand tape in colors so get yellow.
BUT yea you could even use a old gal water or milk jug if needed as long as its clean and dry inside, although not really the best of considerations.
JUST make sure you don't mix-em up with gas. :eek:
2,237
No problem, I do it all the time. I have yellow diesel cans for the tractor, but when I fuel up the PowerStroke, I get 10- 70 cents per gallon discount on up to 35 gallons. Sometimes I can't fit all 35 in the truck, so I put the excess in my atv cans, (like below) & add it later. I'm careful to completely empty the cans before switching fuels, and never had a problem.
http://www.motorcycle-superstore.com/256/d/atv-fuel-cans
Tooljunkie
May 13, 2014
4,150
27
I would make a metal or yellow plastic tag and write diesel on it.
I prefer this method as something dangling will get my attention and remind me to read tag.
I prefer the yellow jug myself, hate the new pour spouts
Doesent matter what you put in jugs as long as its marked.
zake1000
L2800
Jun 18, 2014
20
Athol, MA
Thank you all again for the help with this... feel kind of dumb asking, but better safe than sorry.
I am planning on writing Diesel on the new can (red) with yellow paint, and the idea about a hanging tag would work with me as well, so I'll do that too.
I'm not crazy about all the new spill proof spouts, but the old kind are getting harder and harder to find. I've never had an issue spilling.. I tie my cans down on a section of the tailgate so they don't tip or bounce/slush around when filling them, and so far so good...
2,828
Good deal a clean can and your good to go. And you can thank stupid people and lawyers for the new style fuel cans!
