TG1860 muffler replacement / inner change
crstevent
BX1880 , TG1860
May 6, 2023
19$ixNine69
I purchased this tractor in the spring , the previous owner replaced the muffler with a straight pipe , which has cracked and needs replaced , the stock muffleris no longer available , the only one I've seen is used and the price is on the high side . so I've beeen looking at mufflers that fit other tractors , given that the stock TG1860 muffler had a long tail pipe going down , and the tail pipes on the others that I'm looking at go foward through the grill , I'm thinking that I can use one of these and rotate the muffler so the tail pipe points down and put an extension on it . the mufflers I've looked at range in price from $40 to $120 , part #s 2551-83110 , 2561 - 83110 , 2571-83110 and 2581- 83110 , they all take the same gasket and looking at measurements are very similar in size , guessing the difference being the position of the tail pipe . I'm open to suggestions and finding something that will work for this tractor other then having a new straight pipe made ,
crstevent
BX1880 , TG1860
May 6, 2023
19$ixNine69
I "think" one from a G2160 will work. Probably also NLA, these things are antiques now.
Messicks shows 2 , one for $398 , and one for $632 , just a little more then I want to think about , the difference being in the mounting brackets
5,554
YIKES $632 for just a muffler...
heck for less than that I also got complete 40HP tractor, rear blade and 3 btm plow.
I believe some serious 'bodging' is in order...unless of course you have to 'restore to factory specs'......
or go to ePAY, 2-3 there, though some are 2 legged ? $125 though..used of course.
If it fit/worked, I'd clean it up and paint with VHT paint.
6,383
I just sold a TG1860 (for $500) 'cause I got tired of fiddling with. Exhaust was fine. You might post an ad on FB looking for a parts machine.
I still have a Genuine OEM Kawasaki IGNITER 21119-2116 21119-2157.
lugbolt
ZG127S-54
Oct 15, 2015
5,408
2,103
Mid, South, USA
as far as being antiques , it's only 25 years old vs the early B Models from the 70's whish are almost 50 yrs old
manufacturers are only required to support products for 5 years. Most will continue well beyond that to support them, but I've worked on equipment that is just 6 yrs old at the time, wiring harness NLA. That was a mess!
Cars are often compared with. A 25 year old car, there are a ton of parts that are NLA-I own one. A LOT of stuff is no longer found, even though it's a very popular car. The aftermarket is huge for them, however they don't make everything.
I own a 2000 model Kawasaki Mule. A lot of those parts are NLA. Fuel tank, fuel tank accessories, engine assembly, etc etc. It's only 23 years old.
I also own a late build G1800 (well, it's mine but my mom uses it). A lot of those parts are no longer available.
I own a John Deere JX75 walk-behind. One of the last ones that I could get when the dealer quit selling walk-behinds. 2005-ish I think. Great mower. Lot of those parts, NLA which sucks because it's a wonderful little mower.
I drive a 2003 F-250. You can't get OEM 7.3L parts anymore, Aftermarket only now for some stuff.
I don't like it either but what's our options? Manufacturer has a 5 year requirement, once past that whatever they decide to do, is their decision-not ours.
lmichael
Kubota G2160
Apr 23, 2021
696
324
Rockford IL area
Not sure about our tractors but auto companies are required to supply for 10 years by Fed Law. Pretty sure other things are 7 but I can't find it. Google keeps side tracking the search. FWIW my 2160 (according to the engine number) is 2007 production
