Strange noise in a BX23S PTO
WAS BANNED FOR NSFW PICS
5,149
Today while cutting the field, I noticed a lot of noise coming from under the seat. When I got back to the house, I let it idle in neutral and realized what I was hearing are the gears in the PTO. The PTO was disengaged at the time, and I could clearly hear them turning inside of the case. This may be normal, and it might just be that I never noticed it before. I was using the LandPride 60" FDR1660 for about 3 hours today.
2,768
Check your hydraulic fluid by chance?
With nothing hooked up to either PTO - shift through the 3 settings and see it the noise changes
5,149
You broke it! ;) :p
If you are not joking, would it be covered under the 5-year powertrain warranty? It seems to operate correctly and the fluid level isn't low, The tractor has 190 hours on it, so it is coming up to the 200-hour service. I guess that I can do it 10 hours early, but if it has to come apart to be repaired, then there is no sense in wasting the fluid.
8,487
Yes it was more of a joke than anything else, it's near to impossible for us to know if anything is really wrong without some evidence of what is really going on.
Take a video with sound and post it on You Tube and give us a link to hear it.
And yes if something is wrong it should be covered under the warranty.
