steering boot split on my BX 1870-1
stutrac
110
Bethany ct
i hope this is not going to be a ongoing issue my tractor only has 7hrs, i would thought since i have the most recent one built i would not have this issue so soon,i hope the dealer has a upgrade kit i do not want this issue every year while it is warrantee i have a 45min drive to the dealer,i have read online about a upgrade to the rubber boot i hope the dealer uses them.
tcrote5516
BX1860, FEL, 50" Front Blower, Heated Cab, 6' blade, 3pt carry all, 3pt hitch
Sep 2, 2014
482
Southern New Hampshire
Wow you got 7 hours out of it? That's 3 more than I did :)
Don't worry, with 300hrs on my 1860 that I bought new in 2013 I can tell you its a very well designed tractor with the exception of the tie rod boots and the front axle seals. Both are known issues that shouldn't be issues but in the grand scheme of things are really no big deal. They got the important stuff right.
CountryBumkin
Sep 27, 2015
568
Central FL
What went wrong?
Did Kubota install a defective boot during assembly or did some debris hit the boot? How can the boot just fail - unless it was defective to start with?
It looks like a pain to change.
TripleR
Sep 16, 2011
1,911
SE Missouri
Many don't even bother replacing the boot and just wrap an inner tube or split a hose and zip tie it.
My wife uses ours and I know one of ours went over a year with one torn and there was no damage.
I'm sure with a little shopping, you can find a thicker one, bur new OEM is fine for regular use.
dfh1977
198
east ky
As said in article for part it is # k1253-01660 for replacement part. Basic google search shows several known dealers for part. Mine looks to be dry rotting but says check dealer for replacement part under warranty
3,017
Dr Honda
BX1870
Mar 30, 2015
174
Pitt, PA
My BX1870-1 has 50 hrs... and the boots look new. I'm assuming they either got a bad batch... or it was ripped when installed.
OR....
Since you said it look dry rotted already... maybe it was washed down with a solvent of some kind. (Trying to remove oil or grease?)
Anyway... I've seen boot threads on this board... but I don't think it's widespread.
dfh1977
198
east ky
I tried an email to my dealer from their web site with a picture and part number
7,479
The LINK in the fourth post that TripleR made should be added to a sticky somewhere that makes it easys for other to locate. It is a very detailed review of the installation.
I had a boot rip on a Yamaha Big Bear while spraying weeds. I took the wheel off and cleaned and wrapped the boot with Rescue Tape. It is self sticking and silicone. It's been on there about 4 years now!!! (I took a syringe and injected some grease)
https://www.amazon.com/s/?ie=UTF8&k...qmt=b&hvbmt=bb&hvdev=c&ref=pd_sl_3bygbrar3u_b
tcrote5516
Sep 2, 2014
482
It's dry rot and it is a pretty widespread problem. Mine started doing it within a few months of ownership. I purchased my tractor new and it's been stored in a garage 24x7 when not in use. There's no excuse for that, it's just bad rubber.
trapperdrew
2017 BX23S TLB
Dec 16, 2015
116
Bought mine at the end of Dec. 2015.. just looked at mine and they are all cracked pretty bad. No split yet. I wonder if this is under warranty?
kckndrgn
BX2370 w/ 60" MMM and FEL, Box Blade, Bush Hog, Carry All & Tiller
Mar 17, 2016
150
Somerville, TN
Got my BX in March of this year, and both boots have rips in them. I'm curious if the dealers will do anything. They should IMHO, but it does suck to have to load up the tractor and haul it almost an hour.
Since I plan on doing the maintenance myself it may be a while before I need to take the tractor in for anything.
Still mowen in Ct
BX 1870,Mowing 54 inch belly,FEL for snow and fire wood hauling
Apr 23, 2017
14
tolland cnty ct
STUTRAC and others
I am on my second set in 2 years and the last ones are rotting as I type. Trac is stored indoors.
Sent STUTRAC a private message.
10,598
Bmbbm
Bx2370 land pride box blade 60"mmm kubota fel
May 29, 2016
282
Chillicothe mo
My dealer replaced mine under warranty on my BX2370 with 43 hours. We had to go out on the lot so I could show him what I was talking about to make sure he had the parts in stock. He had a Brand New BX2670 that the boot was already split!
dalola
BX2380 w/FEL & Woods RM48 RFM, Yazoo/Kees Max2 ZTR
Jun 30, 2017
316
Does anyone know if the new 80 series is the same, or did Kubota finally address the problem, and put a new design on the 80's?
Though it's minor, seems to be a bad design that should have been improved several iterations ago. I will be disappointed in Kubota if the 80's are unchanged.
08quadram
bx2350d; Taylor Way 48" tiller; Farm King 50" snow blower
Apr 28, 2014
289
strawberry point, ia
Get ahold of Paul Short (search you tube). Has some some that he came across that are supposed to be very durable.
