Stalling when trying to accelerate
2,726
possible reasons I can think are...
parking brake kinda on ?
crud in tank ?
plugged fuel filters ?
too high a gear ?
too heavy a load ?
plugged air filter ?
1,548
I think Jay covered it well!!!
SO tell us WHAT on the list have to you ........ checked !
3,186
HST?
Does it want to die when you step on the pedal?
Does it do it forwards or backwards
If it is, then seat switch, HST pedal switch, or OPC could be an issue.
If it's a DT (gear) The seat switch or OPC could be causing an issue too.
To add to GreenvilleJay's list :
Water in the seperator.
Charles Dortenzio
L2501
May 19, 2023
Cottreville Twp
HST?
I have changed the filter and fuel, it ran very well for about two hours then started doing the same thing
crud in tank ?
too high a gear ?
too heavy a load ?
Workerbee
Zd21
Mar 1, 2020
124
11
MN
If as you say, that the filter and fuel being changed made it run well for a couple hours, Id think theres crud or debris in your fuel line from the tank to the filter.
Charles Dortenzio
L2501
May 19, 2023
Cottreville Twp
HST?
HST?
yes it stalls out forward & backwards
1,548
I would "look" in the fuel tank and see if debris is blocking the pathway.
3,186
Like I said before it sounds more like an HST pedal switch, seat switch, or OPC issue.
If its stalling consistently when you push the pedal to move it's not a fuel issue.
If you are using it and it starts to bog down then it's more likely a fuel issue.
Just to clarify:
When you say it stalls, does it bog down or does the engine shut off completely?
When sitting still can you move the accelerator lever on the dash up and get rpms up?
ayak
L3301 HST
Feb 16, 2018
504
560
WV
Check out post #9 here (and 21 has a pic of the broken wire that caused this on mine)
