Simple digital tachometer
volp
Kubota B6001, MF35 with backhoe, Ford 3000, JD LX186 Lawn tractor
I was looking for a Tachometer for my B6001 with a D950 engine. The engine got a fitting for a mechanical tachometer but a suitable meter was expensive. :(
The digital tachometers on Ebay were inexpensive. I bought one with sensor for about 13 dollar.
First I fixed the magnet on the front pulley with epoxy.
The sensor was fixed to the frame.
The tachometer was mounted in a plastic box on the top of the dashboard.
The wiring is straightforward.
What is important is that the magnet is mounted with the correct pole towards the sensor! Try first by moving the magnet back and forth in front of the sensor with power connected. If you get no reaction it is the wrong pole and you have to turn it around. I missed that and had to remove the magnet by force and mount a new one! :eek:
You can see a simple digital voltmeter below on the dashboard. I think this is more useful than an ampere meter. ;)
Anders
7,503
That's a nice set up with good visibility.
Tiny Tach has a unit that has a clamp that goes on the injector line and functions off of the pulses from the IP.
ShaunBlake
B6100D; B219; Piranha bar; Hodge stabilizers; Filled Ag rears; R322T w/48" deck
Dec 21, 2014
899
Sugar Hill -- next door to Buford, GA
I was looking for a Tachometer for my B6001...
The digital tachometers on Ebay were inexpensive. I bought one with sensor for about 13 dollar...
Anders
Oh boy! I've been thinking my next upgrade would be a tach, and you've provided the inspiration for a volt meter as well! Your timing is impeccable! :D
Dieselbob
BX 2230, LA211 loader, 60â€￾ MMM, 2â€￾ wheel spacers, grille guard, gauges, bucket e
Nov 17, 2014
196
Fort Wayne IN
After reading your post I was looking at these, my only concern is how susceptable they would be to water. With the BX dash, there are limited places to mount it where it would be protected. I found ALL KINDS of whatproof inductive gas engine tachs, but I couldn't find a single waterproof Hall effect tach. :mad:
volp
Only time will tell how susceptible to water this is.
If you wanted further protection you could glue a small visor on the housing.:cool:
Anders
kubotasam
Apr 26, 2010
1,211
136
Alfred Maine
How close does the magnet need to be to the sensor?
3,019
somewhere I read .....
Power requirement:DC 12/24V
Measure range : 5-9999RPM.
Clear zero: Automatic.
Clear zero time:about 10s.the greater the RPM value,the longer the clear zero time.
Refresh frequency: 0.2-0.5S@120-1200RPM;0.25-0.06S@2400-9999RPM.
Measure indication:RPM<5000,±2;RPM>5000,±3.
Display:RED 0.56” LED
Sign:pusle signal,Hall NPN 3 wires normally open.
Hall proximity model:NJK-5002C
Appearance:M12mm cylinder.
Detection range: 10mm
Proximity output current: 200mA
Detected objects: magnet
Response frequency: 100HZ
Tachometer dimension:72x36x20mm,panel cutout Dimension:68x33mm.
Sensor dimention: M12x10x55mm.
Sensor wiring:brown-Power+;blue-Power-;black-signal.
Operating temperature: 0 to 50°C.
Dieselbob
Nov 17, 2014
196
Fort Wayne IN
OK, I got one of these and am ready to install. One question. On the three wire plug that goes into the back of the readout panel, I'm ASSUMING that the black signal wire from the sensor goes to yellow wire label "IN". Correct? I don't want to fry it right off the bat.
volp
Black is IN!
(Sensor wiring:brown-Power+; blue-Power-; black-signal.)
Anders
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
Gambrills, MD USA
I was wondering do you need to worry about throwing the flywheel out of balance?
Not on a relatively slow moving diesel crank. If you were concerned, you could always glue a similar non magnetic weight 180 degrees on the other side.
With regard to the PTO mount, usually there is an inch of unused shaft, forward of the PTO coupler. You would just have to be careful on hookup, to not knock off the magnet...:D
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
Has anyone installed a Tiny Tach on a B7100 ? Wondering about a location to mount the display.
http://www.tinytach.com/diesel.php
