lightninfan
L2800D, Bush Hog, cutting harrow, disc harrow, post hole digger, spreader
My 2006 2800D w/300 hrs has a flat, the tire size is 27X8.50-15.
Not sure if it's a slow leak, valve stem leak or puncture but given my usage, it's hard to imagine I've got a puncture. Need some advise on how to proceed please.
I think I can get the front axle jacked up and safely supported using a bottle jack and 4x4s. I will chock the rear wheels and no cinder blocks...
I don't have an impact wrench, maybe nows the time to buy one, if that will break the lug nuts. I can tell you my little 3/8 ratchet won't do it. I'm thinking of getting an air impact wrench since I have a compressor. Thoughts?
Once I get the wheel off, could I take it to a local tire shop or would I need to take it to a Kubota shop?
What determines whether to put a tube in it or given it's age, should I just go with a tube?
Finally, re-installing: I'll need to buy a torque wrench, no problem. However, I have all the manuals for the L2800 but can't find the torque spec for front lug nuts.
Needless to say, tractor tires are new territory for me. I'm learning as I go. This forum really helped me on my last tractor issue, hoping for the same again.
Thanks!
Thanks!
