I have a BX15 with a 54 inch mid mower my question is should I cut in low gear or hi gear it seems to cut ok in both just slower in low range I have been cutting in hi but just wanted to ask the pros thanks
That is a excellent question - the real answer is what will the machine handle and how "well" is the grass being cut.I have a BX15 with a 54 inch mid mower my question is should I cut in low gear or hi gear it seems to cut ok in both just slower in low range I have been cutting in hi but just wanted to ask the pros thanks
For the OP - I usually mow in high range. Last few years, I've been mowing my own lawn, plus two others. Probably 2.5 acres total - so been looking to get done sooner than later.....My question is as I'm still in break in period what rpm should I be mowing at . I was running 2200.
I have a B2650 and the 60" deck rides on the ground and gives a great cut, I have also used it suspended in some rough places with good results but the deck is designed to ride on the ground.They are suspended from the tractor. anti-scalping
I know nothing about the B series (which was apparently what the question was asked about) but my BX series manual list the wheels as anti-scalp rollers with rollers to clear the ground between .2 and .5 inches. The cutting height dial is what controls your cut height (obviously).I have a B2650 and the 60" deck rides on the ground and gives a great cut, I have also used it suspended in some rough places with good results but the deck is designed to ride on the ground.
